SF turbo questions?
SF turbo questions?
Looking for a Dyno on a '01 EX with and without a SF turbo. Quarter mile times would be nice also.
What gas does everyone run with the turbo? I have heard 91 or 93. How does this effect mileage?
Does anyone in our around MN have this kit, I am looking to take a ride.
Thanks...
Thanks...
ok.....
ex on 8 psi made 183 whp and 189 ft/lbs of torque
You have to run high octane gas because if you dont the car will detonate ant possibly breaks parts.
The gas mileage is actually increased on highway driving (from my experiences)
thanks to the vtec, the computer automatically takes ignition timing out. The lx does not. If your timing is advanced..... it will be more prone to detonate. So even though the ex has higher compression, the fact that the vtec retards the ignition timing is enough to run a little more boost.
damn you a damn good salesperson. i sell cars so i know
well i have an lx and just reading this post, in stead of buying the base i even gonna upgrade to the alcohol injection, talk to u guys later
Originally posted by Catalyst
alcohol injection
alcohol injection
The alcohol injection is made specifically for running 9-10 psi. So if you plan on needing more than 7 psi, i would recommend the kit. You can change the jets, so if you only want 8 psi, you go with a small jet. If you want 12, you use a big one.
I got a bit of a question concering the SF intercooler. I know that we have to trim down the stock bumper quite a bit, but is there a mesh lower grill that would cover the intercooler but also not impede the air flow into the intercooler. The reason I ask is that looking at some of the pictures, I noticed that certain parts of the frame and actual bumper show through, I just want to hide that and keep the car looking clean.One more thing, will there be a problem with fitting the oem bodykit , not the aero, onto the bumper?
The jets simply unscrew. They are held in with loktite, so they are hard to unscrew. But they are interchangable.
As for the wire mesh, you can put mesh infront of the intercooler, and it will not affect the cooling much. And as for the OEM bodykit, i am not sure, because i have not installed the turbo kit on a car with the stock kit. But i am pretty sure that since you only trim out the grill, the kit will still fit fine.
well, i just called mike a little bit ago and they just pulled into vegas for the SEMA show. Anywayz, i sent in my payment for my kit. I can't wait......boost....here i come !!!!!
Does the LX dyno higher at 8 PSI?
ok.....
ok.....
Retired - SoCal FI Mod
Originally posted by paolomonroe
So WHAT'S THE FASTEST TIME ANYONE HAS PUT DOWN ON A QUARTER MILE WITH THIS KIT? hOW BOUT SOME TIME SLIPS AND DYNO'S
