SF turbo questions?
Old Nov 1, 2003
Demented's Avatar
Demented is an unknown quantity at this point
SF turbo questions?
Looking for a Dyno on a '01 EX with and without a SF turbo. Quarter mile times would be nice also.
What gas does everyone run with the turbo? I have heard 91 or 93. How does this effect mileage?
Does anyone in our around MN have this kit, I am looking to take a ride.
Thanks...
Old Nov 1, 2003
dragoon's Avatar
pm catalyst or sfpower, or do a search.
thanks.
Old Nov 1, 2003
Demented's Avatar
dragoon,
I did search before posting and only found one dyno. But thanks for the tip. Still looking for info on gas and a local turbo owner.
Old Nov 1, 2003
dragoon's Avatar
http://www.7thgencivic.com/forums/sh...threadid=96438
page 4
Old Nov 1, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
ok.....
ex on 8 psi made 183 whp and 189 ft/lbs of torque
You have to run high octane gas because if you dont the car will detonate ant possibly breaks parts.
The gas mileage is actually increased on highway driving (from my experiences)
Old Nov 2, 2003
EnProceso's Avatar
will 91 octane be good enough?
Old Nov 2, 2003
Catalyst's Avatar
I use 91 octane. It is good for about 6-7 psi daily on an lx, and about 7-8 psi daily on an ex.
Old Nov 2, 2003
Elite's Avatar
Elite is an unknown quantity at this point
nice to see an extra 2psi it always helps? btw why? what happens when you throw the cat how much hp is gained? on an ex?
Old Nov 2, 2003
Catalyst's Avatar
you can gain anywhere from 10-50 whp. Depending on the cat, car, boost, turbo, etc
Old Nov 2, 2003
Demented's Avatar
Thanks for the replies guys.
Does anyone around MN have this turbo installed? I really want to take a look at it in person.
Old Nov 2, 2003
dragoon's Avatar
Post it up in the local forums, someone might have it.
There's a couple vids you can watch here and there also, if nobody bites.
Old Nov 2, 2003
CivicRacer5's Avatar
CivicRacer5 is an unknown quantity at this point
why can you run more boost on an ex? Doesnt it have higher compression?
Old Nov 2, 2003
Catalyst's Avatar
thanks to the vtec, the computer automatically takes ignition timing out. The lx does not. If your timing is advanced..... it will be more prone to detonate. So even though the ex has higher compression, the fact that the vtec retards the ignition timing is enough to run a little more boost.
Old Nov 2, 2003
so what needs to be done to the LX to run a higher boost safely daily?
Old Nov 3, 2003
Catalyst's Avatar
alcohol injection
Old Nov 3, 2003
024drlx's Avatar
024drlx is an unknown quantity at this point
damn you a damn good salesperson. i sell cars so i know
well i have an lx and just reading this post, in stead of buying the base i even gonna upgrade to the alcohol injection, talk to u guys later
Originally posted by Catalyst
alcohol injection
Old Nov 3, 2003
civic01vtec's Avatar
is it worth getting the W/A injection if i have an EX then ?
Old Nov 3, 2003
^^^and i bet that u are gonna say yes !!!!
Old Nov 3, 2003
Catalyst's Avatar
yes
Old Nov 3, 2003
Catalyst's Avatar
The alcohol injection is made specifically for running 9-10 psi. So if you plan on needing more than 7 psi, i would recommend the kit. You can change the jets, so if you only want 8 psi, you go with a small jet. If you want 12, you use a big one.
Old Nov 3, 2003
so depending on how much boost your gonna run, you have to switch the alcohol injection jets? How hard is it to switch a jet?
Old Nov 3, 2003
SilverSivic02's Avatar
SilverSivic02 is an unknown quantity at this point
I got a bit of a question concering the SF intercooler. I know that we have to trim down the stock bumper quite a bit, but is there a mesh lower grill that would cover the intercooler but also not impede the air flow into the intercooler. The reason I ask is that looking at some of the pictures, I noticed that certain parts of the frame and actual bumper show through, I just want to hide that and keep the car looking clean.One more thing, will there be a problem with fitting the oem bodykit , not the aero, onto the bumper?
Old Nov 3, 2003
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
ummm, i understand your concern, but if i saw a freakin SF intercooler in your front bumper, i wouldntbe concerned with all the other stuf showin
Old Nov 3, 2003
Catalyst's Avatar
The jets simply unscrew. They are held in with loktite, so they are hard to unscrew. But they are interchangable.
As for the wire mesh, you can put mesh infront of the intercooler, and it will not affect the cooling much. And as for the OEM bodykit, i am not sure, because i have not installed the turbo kit on a car with the stock kit. But i am pretty sure that since you only trim out the grill, the kit will still fit fine.
Old Nov 3, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
i have OEM kit.. fitrs FINE... trim and its all goood
Old Nov 4, 2003
well, i just called mike a little bit ago and they just pulled into vegas for the SEMA show. Anywayz, i sent in my payment for my kit. I can't wait......boost....here i come !!!!!
Old Nov 5, 2003
Diemos's Avatar
Diemos is an unknown quantity at this point
Does the LX dyno higher at 8 PSI?
ok.....
Old Nov 5, 2003
i don't know the specs, but i highly doubt that the LX will dyno higher than the EX.
Old Nov 5, 2003
paolomonroe's Avatar
paolomonroe is an unknown quantity at this point
So WHAT'S THE FASTEST TIME ANYONE HAS PUT DOWN ON A QUARTER MILE WITH THIS KIT? hOW BOUT SOME TIME SLIPS AND DYNO'S
Old Nov 5, 2003
iamboo's Avatar
Retired - SoCal FI Mod
catalyst pulled a 13.6 at 9psi i believe... he has the timeslips in the NEW timeslip section of this site... i think the EX pulled 185whp at 5-6 psi... that's pretty impressive if you ask me...
