Ok, lets just make this point blank.... (Springs)
Old Oct 27, 2003
obtix's Avatar
www.AbsouluteDriven.com
obtix is an unknown quantity at this point
Ok, not beating around the bush here.. I want springs that will give my ride about a 1 to 2 inch drop. I want the springs to be stiff possibly 250 - 300 pounds. Ideas?
Old Oct 27, 2003
PunkingCivic's Avatar
I need TP for my bunghole
buy mine check above the sig
they are the sports 1.75 in front and 1.5 in the rear
Old Oct 27, 2003
obtix's Avatar
Odd, I thought most springs lowered more in the rear then front. What are they rated at?
Old Oct 27, 2003
civicvtec1ps's Avatar
Search and Learn
250 front and 300 rear? is that what you are asking? rear springs are alot stiffer than front springs. i dont think theres any springs that are on market that much stiff. why would you want that stiff springs? track use? you will probably need to replace shocks with those stiff springs.
Old Oct 27, 2003
ISO 9002 is all that I got from the neuspeed site.
Old Oct 27, 2003
Search and Learn
you can possibly fit springs that are made for new si i guess, im using tein s tech springs that are made for em2. heres progress info.
280 front and 500 rear Drop: 1.8" front and 1.5" rear.
Old Oct 27, 2003
obtix's Avatar
I was debaiting on get Skunk2's that are rated at almost 500. I love my friends TRD springs on his celica they are around 300. I'm gonna be running track and scca btw, this is gonna also be an every-other-day driver.
Old Oct 27, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
u gotta need new shocks if u get that stiff springs, i was running h&r sports and as soon as i autox (back in this July), the stock shocks perforamce is decreasing each time, if u are crazy about lapping, its definitely worth it to get a set of coilovers
Old Oct 27, 2003
Zzyzx's Avatar
Autocross Junky
Just a note, but I understand that Koni yellows in stock trim are only good up to about 450LB/in - 500LB/in. any thing higher then that and I'd be a good Idea to talk to Koni and get them revalved for the stiffer springs.
Old Oct 27, 2003
robbclark1's Avatar
Retired suspension supermod.
you can always get custom spring rates from most companies. it will cost you thought. if you call up neuspeed and say you want a set of neuspeed springs with such and such rates they should be able to make them for you. don't know the cost though
Old Oct 27, 2003
dragoon's Avatar
As far as I've experienced, tein S.tech are extremely soft and not geared towards performance. I'd go with eibach sportline.
Old Oct 27, 2003
obtix's Avatar
HRM, the Sportlines seem a little to soft for me but for some reason they keep getting suggested to me. Also, I am going to be doing shocks but I'm just asking about springs now. Thanks though...
Old Oct 28, 2003
Snort2001's Avatar
Snort2001 is an unknown quantity at this point
yup, when i had my 2 w7s in my trunk, i needed to get stiffer springs that carry more weight, so i called up ground control and they sent me stiffer ones that carry about 550lbs each for the rear. cost me $50 each.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
cruisers10
May 12, 2015 10:46 PM
oneheadlight
Apr 29, 2015 11:30 PM
ImmortalEX
Oct 31, 2001 10:00 PM
