Ok, lets just make this point blank.... (Springs)
www.AbsouluteDriven.com
Ok, not beating around the bush here.. I want springs that will give my ride about a 1 to 2 inch drop. I want the springs to be stiff possibly 250 - 300 pounds. Ideas?
Originally posted by PunkingCivic
buy mine check above the sig
they are the sports 1.75 in front and 1.5 in the rear
Search and Learn
250 front and 300 rear? is that what you are asking? rear springs are alot stiffer than front springs. i dont think theres any springs that are on market that much stiff. why would you want that stiff springs? track use? you will probably need to replace shocks with those stiff springs.
Search and Learn
you can possibly fit springs that are made for new si i guess, im using tein s tech springs that are made for em2. heres progress info.
280 front and 500 rear Drop: 1.8" front and 1.5" rear.
u gotta need new shocks if u get that stiff springs, i was running h&r sports and as soon as i autox (back in this July), the stock shocks perforamce is decreasing each time, if u are crazy about lapping, its definitely worth it to get a set of coilovers
Autocross Junky
Just a note, but I understand that Koni yellows in stock trim are only good up to about 450LB/in - 500LB/in. any thing higher then that and I'd be a good Idea to talk to Koni and get them revalved for the stiffer springs.
you can always get custom spring rates from most companies. it will cost you thought. if you call up neuspeed and say you want a set of neuspeed springs with such and such rates they should be able to make them for you. don't know the cost though
HRM, the Sportlines seem a little to soft for me but for some reason they keep getting suggested to me. Also, I am going to be doing shocks but I'm just asking about springs now. Thanks though...
oneheadlight
Apr 29, 2015 11:30 PM
