engine diagram needed
Old Oct 25, 2003
nunzio42's Avatar
nunzio42 is an unknown quantity at this point
I am looking for an engine diagram but could not find one. I am specifically looking to see which hose is what......is there a site i can go to . I will attempt to post a pic of what specific hose i alooking for is, but in the meantime...is there a diagram of my engine anywhere?
Phil
2003 EX
Old Oct 25, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
I'm not aware of a full schematic.
www.hondaautomotiveparts.com
you can run through the parts database schematics by system, and figure out what hose it is... or you can take a picture of it, or tell us what you want to do and maybe someone can help you out.
Old Oct 25, 2003
Voiceofid's Avatar
End Bringer
most of your hose are listed under the hood, on your emissions sticket
Old Oct 25, 2003
nunzio42's Avatar
need to find this out
Old Oct 25, 2003
Got Boost???'s Avatar
I believe that is the Evaporative Emission (EVAP) canister hose
Ok follow the hose and if it meets up with a small 90 degree bent metal pipe that goes off to the drivers side of the engine bay, then that is the EVAP canister hose.
Old Oct 25, 2003
nunzio42's Avatar
Does it do anything??? possibly set off the lil check engine light? (notice the elctrical tape?.....accidently cut the hose)
Old Oct 25, 2003
Voiceofid's Avatar
End Bringer
it might if your system is letting in false air, or leaking out
Old Oct 25, 2003
nunzio42's Avatar
Thanks much!
Old Oct 26, 2003
Jap-Euro Fusion
Did you cut through it? or just the top layer? It has a liner pipe inside the rubber hose, so you should be ok. If it bugs you, then get some rubber sealant and seal the cut up.
Old Oct 26, 2003
nunzio42's Avatar
completly replaced it yesterday, hopefully it solves the problem....there was a nice hole in it
Old Oct 26, 2003
This is from the Honda Civic service manual
"The EVAP controls minimize the amount of fuel vapor escaping into the atmosphere. Vapor from the fuel tank is temporarily stored in the EVAP canister until it can be purged from the EVAP canister into the engine and burned."
Simply put, ever opened the gas cap in a car other than your civic? Hear that psssshhhhh sound? thats evaporated gas escaping from your fuel tank, the EVAP system simply catches that evaporated gas and stores it so it can be used as fuel later on. So the purpose of the EVAP system is to make use of the evaporated gas that would otherwise be lost.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
mievil
Apr 28, 2015 11:02 PM
darwin-t
Apr 18, 2015 09:29 PM
Uncle X
Apr 15, 2015 09:59 PM
Myredjonda
Apr 14, 2015 07:00 PM
