2003 headunit
Old Oct 24, 2003
lid6662's Avatar
lid6662 is an unknown quantity at this point
2003 headunit
OK has anyone replaced there stock headunit in a 2003? Because right now my ac and power to my radio does not work at all. I checked the fuses and there good. Also My dimmer controls reset evertime i start the car. Also my keyless entry does not work. Any ideas what i can check becasue the dimmer thing and the power to radio ac does not work at all?
-matt
Old Oct 24, 2003
psykh00's Avatar
psykh00 is an unknown quantity at this point
I replaced mine with an alpine unit a few months ago. Afterwards, a few things weren't working, like power doorlocks, my trip a/b odometers reset every time, and some other electrical things. Did you check all of the fuses? I first checked my fuses that dealt directly with the things that were wrong. But the fuse that I found to be blown wasn't what I expected. A blown fuse almost anywhere can affect the rest. A short in the branching fuse system at one point just messes up other things in that network of fuses.
So if you didn't check all of the fuses, go through and pull out each one and check them all.
Old Oct 24, 2003
lid6662's Avatar
Ok I checked all the fues under the hood and the steering wheel and the radio and ac still do not have any power any ideas?
Did i Mess up my electic system in my car? Iam kinda worried
Old Oct 24, 2003
xstrghstx2k1's Avatar
xstrghstx2k1 is an unknown quantity at this point
Make sure that you did not hit any other wires when installing the play.. i would take it out and check to see if you sliced through a wire unexpectidly because there are some vital wires that run to the ac and steering wheel behind the main dash..
Old Oct 24, 2003
lid6662's Avatar
I think some of the wires were touching and made a spark and now it wont work. I forgot to disconnect the battery
But yea i hook up my old headunit and nothinhg and the ac button does not work?
Should i take it to honda?
Old Oct 24, 2003
psykh00's Avatar
If I were you, I would ask one of the technicians at Honda. Just explain your problem to him and ask him what he thinks the problem could possibly be. The mechanic at my dealer tells what he thinks could be wrong. Then I go check it out myself. Normally he's right. And it doesn't cost anything to get advice.
Old Oct 24, 2003
skipbarber's Avatar
its definately a blown fuse, and if it keeps blowing, something is grounding out. retrace your steps and dont panic.
Old Oct 24, 2003
lid6662's Avatar
But i Checked all the fuses and pulled out everything back to stock headunit? The only radio\ac fuse is under the steering wheel right??
Old Oct 24, 2003
skipbarber's Avatar
it'll be under the hood
Old Oct 24, 2003
lid6662's Avatar
Iam just worried i Screwed my car up! Is it a normal size fuse or a big one cause i didt see one at all for the radio under the hood!
Old Oct 24, 2003
vietfob714's Avatar
vietfob714 is an unknown quantity at this point
I put a deck in my 03 civic and nothing happened...works perfectly fine... just take the harness off and reconnect them again.. with butt connectors or whatever method you did to connect the aftermarket cd player harness and the harness that goes to ur stock harness... maybe that'll undo any loose wires...
Old Oct 24, 2003
Metallica454's Avatar
The Beer-man
Metallica454 is an unknown quantity at this point
Hey buddy, a fuse can only blow once. And if a fuse did blow, then that doesnt been your system is grounded out. These are 2 opposite situations. A Blown fuse is an open and a ground out is a short.
If a fuse did blow out, then you have too much current flowing through your circuitry. Fuses are designed to protect your electronics by burning out when too much current is present. So, if you replace your fuse it'll just burn out again. If you replace it with a higher amp rating, you run the risk of farking up your whole electrical system.
Of course do not rule out the possibility that some wires are shorted or are grounding out. If you have any piece of exposed wires touching anthing metal, you just need to tape 'em up with electrical tape.
Old Oct 24, 2003
lid6662's Avatar
Ok You guys were right it was a fuse called backup. YEa everthing works now
The only problem now is i cant seem to find the trim that goes around my kenwood cd player? It was in my car last night but not there this morniing. Well thats the least of my worries!
Old Oct 24, 2003
The Beer-man
Something caused a surge of current to run through your electronics and blow out your fuse. It is possible for it to happen again. A new fuse might just be a temporary fix. I'm not saying it will happen, it just could.
Old Oct 24, 2003
fine02civicgurl's Avatar
*BoY*CaR* *GiRL*DRivER*
fine02civicgurl is an unknown quantity at this point
they sell em at walmart. i didnt even use the one that came w/mine i dont think.
Old Oct 25, 2003
nunzio42's Avatar
nunzio42 is an unknown quantity at this point
put the stock back in and bring it to honda....be like...hey my stff aint workin anymore. It works!
Old Oct 25, 2003
Voiceofid's Avatar
End Bringer
and we dealer technians hate people like you
Old Oct 25, 2003
nunzio42's Avatar
hehe, sorry.....i havent done this yet....but when i had my a4....i was replacing the ecu everytime i went in for service!
I know yall hate the people that do that, but at the same time can u blame us?....well yah u can blame us literally, but i mean **** wouldnt u do the same?
Old Oct 26, 2003
do yall know when we do stuff like that? is it obvious that the stuff has been replaced then put back in?
Old Oct 26, 2003
4Saris's Avatar
4Saris is an unknown quantity at this point
Doesn't that help your job security?
Generally you can tell when someone has already removed something and returned it back to stock. Right?
When I worked at a bike shop, people would come in with some messed up shiite and say, I was "Just Riding Along". We called them the JRA's. I bet people come in with stuff you know they messed up and say they were "Just Driving Along".
Old Oct 26, 2003
greggdogg's Avatar
greggdogg is an unknown quantity at this point
Wait, what dimmer control? Mine only controls the gauge lights.
jdawgzcivic
17
Feb 1, 2020 04:16 PM
sesi
Oct 1, 2015 02:03 PM
Raiool
Oct 1, 2015 10:42 AM
ken4444
Sep 30, 2015 07:37 PM
blward6
Sep 16, 2015 05:32 PM
