High compression
Old Oct 20, 2003
boo's Avatar
boo
boo is an unknown quantity at this point
Question High compression
If I decide to upgrade and go with higher compression(thinking 10.8:1 from dh racing) how would I address the fuel issue? or is there even a way? thank you in advance for any help on this.
Old Oct 20, 2003
cambo's Avatar
I wish I was asian
jus use higher octane gas.
Old Oct 20, 2003
boo's Avatar
boo
thats all i need is higher octane gas? i won't be running lean or anything? and also is it still safe to use nitrous with that setup? I will be upgrading the rods as well
Old Oct 20, 2003
dj02's Avatar
if ur going to go FI why do u want to up you'r compression? lower compression when going with nitrous, or turbo is the best.
Old Oct 20, 2003
03civicdx's Avatar
03civicdx is an unknown quantity at this point
the computer should make up for the fuel mapping up to a certain extent otherwise you can search for the DIY of a inline fuel pump and slap a fuel pressure regulator on it and it should help with your problem
Old Oct 20, 2003
boo's Avatar
boo
I don't want to go turbo due to all the ongoing maintence required with it. Its a non-stop process trying to keep it running and i don't want that. I'm going with the higher compression to have a little extra power under normal driving and nitrous is just nice for when you need that extra boost. But can anyone tell me if they've done this or not??? thank you
Old Oct 20, 2003
Voiceofid's Avatar
End Bringer
Re: High compression
seems like just higher octane gas will work.. your engine will run hotter, uh.. might want to look into the egr valve, because that will try it's best to keep NOx down
we do have a fuel pressure regulator, it's in the fuel tank
Old Oct 20, 2003
03civicdx's Avatar
im sorry an easily adjustable fuel pressure regulator, the computer maps it out more then an older car with a manual fuel presure regulator sorry for the poor wording on my last comment
Old Oct 20, 2003
mclean987's Avatar
mclean987 is an unknown quantity at this point
i know people than run 13.0 compression ratio you just need proper tuning and to retard timing, im in the process of building my hih comp motor but thats with a d16 someone on here used some gx high compressions pistons in there engine the power was great but they had overheating problems
Old Oct 21, 2003
reytito's Avatar
yeah i think that was chrissy...
Old Oct 21, 2003
Green Civic's Avatar
You will have to do ongoing maintaince on n/a or turbo setup. The parts just change in what you will have to do maintaince on.
Old Oct 21, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
mclean987 buddy...if you add more compression you need to add more octane or you will detonate. If you retard your ignition timing it is cancelling out the compression you just added...read your other thread i replied in more detail there...
If you want to make power you want to advance your timing...read up on some facts before YOU give advice on something your BUDDY doesn't know about.
Old Oct 21, 2003
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
And how do we know "Chrissy" even did anything she said??
Listen, Boo, I've been thinking about doing this too, and the computer should adjust for the higher compression. 10.8:1 isn't too high, but you will have to start using premium gas. I don't think there's one person on this site who's done this cuz they're all to scared or something. So be a pioneer and let us know. I just don't have the cash on me to do this project.
Old Oct 21, 2003
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
Just curious, I have some money to burn, but I am hesitant on the turbo mod. How much would a high compression piston + ring set cost me + labor??
Old Oct 21, 2003
mclean987's Avatar
well if you notice i said tuning is the key so obviously when you tune you will adjust timing where it sposed 2 be, i know people who run d16a1 and d16a6 p29 jdm dome pistons in there sohc vtec with a **** load of mods and cams and no b series engine can beat it
Old Oct 21, 2003
boo's Avatar
boo
Its different trying to tune a d17 compared to a d16. If the D17 was easy to tune people would be doing it then........has anyone adapted an aftermarket radiator to our cars or is there one for it to address the overheating issue?
Old Oct 22, 2003
Jeremy's Iron
The whole package should cost you less that $1000. I could get it done for about $500 but I just don't have the money. My uncle is a mechanic and he could hook me up with cheap labor. The pistons/rings should cost you at the most $300 - $330. That's not including rods..
Old Oct 22, 2003
Voiceofid's Avatar
End Bringer
i never read the thread about the gx pistons chrissy had
but i am sure she probably killed her cat, and her egr
if it was simply adding higher compression pistons into the car, there would've already been d17s out there running that compression, obviously, it's more difficult dealing with that overheating than just a simple bigger radiator
Old Oct 22, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
you would need to retard the ignition timing elctronically through hondata
or JetChip. not retard the cam gear..
Old Oct 22, 2003
C2i0v0i1C's Avatar
SuperMODrizd
hondata doesnt exist for our cars and never will according to them, i wouldnt say jet chip either, bc once u do it i dont think u can change it back correct me if im wrong, i retarded my timing with the emanage
Old Oct 22, 2003
xblkcivicx's Avatar
And what is your "tuning" consist of? and like i said if you raise the compression and retard the ignition...your cancelling each other out...get a clue.
Old Oct 23, 2003
C2i0v0i1C's Avatar
SuperMODrizd
mine consists of a turbo where that is beneficial
Old Oct 23, 2003
Jeremy's Iron
but would it be so hard for someone out there to at least try it? it seems like most people who have a D17 in their car is afraid to change their internals. i mean, i go on clubrsx, and a lot of people there upgrade all kinds of crap in their engines. they upgrade everything from pistons, intake manifolds, cams, and more. if more people with D17's tried to change the internals, and revealed actual results, i think we'd all see that it's possible to have a faster car without an engine swap.
[/rant]
Old Oct 23, 2003
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
ok... so how much HP to the wheels should this upgrade possibly add??? that's the most important part of all
Old Oct 23, 2003
Jeremy's Iron
what do i look like? a dyno?
j/k. seriously i don't know. it should add some actual "noticeable" power compared to what we have now, though.
again, NO ONE will know unless SOMEONE tries it, and then let's everyone else know.
SimpleUser
Apr 24, 2021 02:54 AM
darwin-t
Aug 15, 2015 10:51 AM
DerbyDad03
Jul 27, 2015 11:34 AM
silentz
Jul 9, 2015 08:16 PM
CivicsClass101
Jul 9, 2015 11:14 AM
