Just installed vtec indicator led...
Old Oct 19, 2003
silverslug's Avatar
silverslug is an unknown quantity at this point
I just installed a blue led vtec indicator on a 02 EX coupe. I followed the instructions from a website. I used a 330 ohm reistor on the led and tapped it to the green w/yellow stripe wire of the ECU. And grounded the other end of LED. NOW,,, the problem is that the LED comes on around 2,500 to 3,000 rpms depending driving conditions. It stays on all the time on the freeway going 70 mph @+ or - 3000 rpms. Isn't the vtec engagment at around 4,500 RPM ? Did I tag the wrong wire? BTW, I looked under the hood at the vtec solenoid, the color of the wire is also green w/ yellow stripe.
Old Oct 19, 2003
Connie's Avatar
Well, you did it exactly right
VTEC engages around what you are saying but it doesn't kick in fully until around 4500+ rpms.
Old Oct 19, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
yep... u did right
our motors seem to have a sorta ivtec ... I don't think it's 3 stage ... maybe 2 stage (2500, 4500 rpm)
Old Oct 19, 2003
horatio's Avatar
horatio is an unknown quantity at this point
you did it right...mine does the same thing...kicks in at about 3k....you cant "feel" it kick in it about 4.5k though. vtec stays on when you are cruising above 65-70 mph to.
Old Oct 19, 2003
go02civic's Avatar
go02civic is an unknown quantity at this point
what is the whole point in having one in your car? it doesnt do anything special
Old Oct 19, 2003
Connie's Avatar
Looks, I get comments on how it is cool, and I don't want to take it out and leave a hole in my dash, thats the only reason it is still there.
Old Oct 19, 2003
Niter1dah's Avatar
Niter1dah is an unknown quantity at this point
Thats pretty cool I wouldnt mind building a setup sort of like how a bimmer has lights going backwards the closer you get to redline on the tach.
Old Oct 19, 2003
silverslug's Avatar
My LED in located inside the instrument gauge cluster between the tach and speedo. Anyways, how do I get it to light up at 4,500 rpms instead of 2500+rpms? I am currently using a 5 volt LED, would say a 12 volt LED keep it from lighting until 4,500rpm? thanx. If it doesn"t work, i might convert it into a shift light instead.
Old Oct 19, 2003
CapYoda's Avatar
Escaped Convict
they say thats right.
vtec does engage at that point and the other points..
diff. stages.. still debatable on our vtec stages... is certainly not totally like the prevoius gen.
Old Oct 19, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
you cant change the led and get the computer to change when it engages VTEC. it doesn't work like that. The general assumption is that the timing advances when the light comes on, and the cam profile is shifted later on in the process... probably by some kind of oil pressure sensor.
Old Oct 19, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
SO WHAT WE NEED is that SIGNAL from the oil sending unit that pushes the cam over,, anyone know which wire this is?
Old Oct 20, 2003
Stone's Avatar
Stone is an unknown quantity at this point
The Vtec timing part engages at full throttle above i think 2500 or so, then at 3000-3200 no matter what.
I think it actually switches to the other lobe at 4400.
I think the signal from the oil sensor goes to the ECU, then to the solenoid.
Im not sure how it works, but i would rather that the light come on at 4400 than all the time at 3K, wouldnt you?
Old Oct 20, 2003
silverslug's Avatar
The wire color of the VTEC oil pressure switch wire is blue w/ black tracer. It's located on the same ecu (white) harness plug. I tried tagging that wire instead and the LED still lights up at around 3,000 rpms regardless.
Old Oct 20, 2003
MangoEX's Avatar
Just Be
what about that VTEC (blue wire) solenoid wire under the hood? what if we tap into that...
Old Oct 20, 2003
Stone's Avatar
That might work.
Give it a try and let us know what happens.
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
dbagaus
70
Feb 22, 2023 04:26 PM
jimmyfloyd
May 20, 2015 07:06 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
injencivic
Nov 9, 2007 02:31 PM
