Camber bolt
Camber bolt
Hey i was just wondering what a camber bolt is. Is it the same as a camber kit?? i did a quick search on google n it says its used to adjust the wheels camber setting... So is it the same as a camber kit??
thnx
thnx
there is in fact a camber bolt but only for the front. for the rear you need an adjustable upper arm. This should probably be in the suspension section .
Search and Learn
front camber kit is cheaper obviously, just bolts
01-02 uses 14mm
03 uses 16mm just like new si's and rsx's
Dave Brabant
20
Oct 6, 2015 12:44 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
