Wiring fog lights to parking lights positive wire..
Old Oct 5, 2003
syndrome's Avatar
syndrome is an unknown quantity at this point
I just screwed in some new foggies and want to connect them to my parking lights so they turn on together but have a few questions before I do:
1. what color wire do I splice into and can I connect both fog positives together and just hook into one parking light positive?
2. is it *safe* to do this? I mean it wont short-out the harness at all would it?
3. how do you reccomend I splice into this wire?
thanks guys.
Old Oct 5, 2003
MatrixShark's Avatar
MatrixShark is an unknown quantity at this point
I did exactly what you are proposing. I did this for a few reasons. The biggest reason being simplicity. So YES it is possible.
Watch out for the wattage of your bulbs! Mine are 55watts each and I have had no problems. Anything higher and you could draw too much current. I have been using this setup for over four months.
I wired each into its own side. I used snap in wire tap connectors, some people call them "scotch locks". I'm sorry I don't remember the colors of the wires. Use a test light or multi-meter.
Old Oct 5, 2003
vietfob714's Avatar
vietfob714 is an unknown quantity at this point
I know for sure the red and the green wires are power... and the 3rd wire is ground.... so its one of those two...hope that helps... yeah use T taps and male connectors... works great!
Old Oct 5, 2003
I was bored. Here is a VERY simple wire diagram.
Old Oct 5, 2003
Here's a tip: Use bullet connectors about two inches away from your fogs. This way when you want to pull your front bumper off you can quickly disconnect and then reattach the wires. You don't pull the bumper cover off very often but when you do this saves ALOT of time.
Old Oct 5, 2003
syndrome's Avatar
Thanks guys, I just went out and bought these 3M Quick Connector plastic thingys that got 2 holes for 2 wires and just snaps down, its all that Pep Boys had but I think its what you're talking about right? but what gauge are the wires down there, I got connectors for 22-16 awg.
Old Oct 5, 2003
p.s. Radio Shack sells the scotch locks. part number 64-3052 $1.99
Old Oct 5, 2003
Hey mods... Sticky this DIY.
EDIT- Thanks
Old Oct 5, 2003
syndrome's Avatar
the blue one is exactly what I got =) thanks shark.
Old Oct 5, 2003
Originally posted by syndrome
...but what gauge are the wires down there, I got connectors for 22-16 awg.
I'm not sure of the wires exact gauge. You say you bought the blue connectors. Typically the red is for the thinnest gauge, then blue, and finally yelow is for the thickest wires. I used blue and that is what you want for this application.
Old Oct 16, 2003
blckpwdr's Avatar
blckpwdr is an unknown quantity at this point
you really should use relays to isolate the wires. the way you are describing is going to cause more current to go to both lights and they usually end up melting.
Old Oct 16, 2003
^^This is a possibility. I highly reccommend using fairly low wattage fog lights. As I stated above I am using 50 watt ea. bulbs. They are working great and have run flawlessly for months. The parking lights obviously draw a certain amount of current. By "piggy-backing" the fogs on the same wiring you are pulling that much more current through the same circuit. This could quickly become too much. Once that happens a fuse should blow. If not then the wires or switch could possibly burn out. If you are using larger type fogs then do as blckpwdr suggests and use relays.
A proper (relay) setup could use the parking lights as the trigger for the relay. Then with (fuse protected) direct battery power, you would have no problems and could run whatever size fogs you want.
The bottom line is: This "piggy-back" method works but "try it at your own risk".
Old Oct 19, 2003
ricehead's Avatar
ricehead is an unknown quantity at this point
does the 04 LX have the wires for the fog lights behind the front bumper? or do you have to do the wiring yourself if you get the factory fog kit?
Old Oct 19, 2003
If you get the factory fog light kit, you should be able to plug into the harness that is already there.
Old Oct 21, 2003
ferio's Avatar
ferio is an unknown quantity at this point
are you saying that i can do this with my oem fogs? if i do this diy can i pm you for further questions matrix?
Old Oct 21, 2003
I would check the wattage of the oem units. If they draw alot of current use the relay setup. It pretty easy to use relays anyway.
If you have little questions feel free to pm me. However, if it's something that all can benefit from, please post your questions here in this thread.
Old Oct 21, 2003
ferio's Avatar
ok.. can anyone post the wattage of the oem style h11 bulbs? i don't know if the "copys" have the same wattage as the original ones.. thanks matrix!
Old Jul 26, 2004
flammable911's Avatar
flammable911 is an unknown quantity at this point
I have some sweet fogs that fit into my evo5 body kit on my 03 civic lx. I'm trying to get them figured out and can't make much sence of the posts. I have three wires coming off the lights: red, black, and white. I have one bulb in the middle and another is mounted a little higher. It seems like they are set up for being switched between bright and dim... I could be wrong. They didn't come with any kind of switch or wiring or anything so I have no idea how they are supposed to get wired up! They are mounted up great and what I would like to do is rig them to their own switch if possible. Any ideas PLEASE let me know, I'm dyin here.... Thanks guys!
Old Oct 22, 2018
Robbief95's Avatar
Robbief95 is an unknown quantity at this point
Re: Wiring fog lights to parking lights positive wire..
Hey
I want to patch in my foggies to the parking lights but I don't want them to come on when low beam is on does anyone have a solution??
Thanks
Old Oct 22, 2018
BrotatoChip's Avatar
Super Moderator
Why would you not want them on with low beams?
Using a couple relays this can easily be done. Take a normally open relay that closes when the parking light comes on (there is a spot in the under dash fuse box that will give you this) then a normally closed relay that opens when the low beams are on (also under dash fuse box I believe) after that. Run the power for the fog lights through both relays in series.
Old Oct 22, 2018
Robbief95's Avatar
Hi
thanks for the reply could you please attach a photo or diagram to where exactly i need to put the relays.
the reason im doing this is where i am its illegal to have your foggies on with your low beams which is stupied but you have to do it i guess
thanks
Old Oct 22, 2018
Super Moderator
Any experience using a multimeter? Wouldn't take you long to figure out where you would need to connect both relays. I can get you a picture but you will have to wait until I'm home from work.
Old Oct 22, 2018
Robbief95's Avatar
Hi
i can wait i just dont want to go raming in the tongs ***** nilly and something to short out or stuff up so all good picture would help big time
thanks
Old Oct 22, 2018
Robbief95's Avatar
Hi
are you sure the relays are under the stearing coloumn i just had a look and only saw one
thanks
Old Oct 22, 2018
Super Moderator
I sent you a PM.
Old Oct 23, 2018
Robbief95's Avatar
Hi
thanks for that
SSMCivicCoupe
Lighting
Sep 20, 2011 04:48 AM
RallyeRedRider
Jun 14, 2008 05:36 PM
MDCIVIC28962
Mar 4, 2008 07:51 PM
DarkCivic
North East
Mar 15, 2004 04:23 PM
PlatnumBomb
Aug 13, 2002 12:41 AM
