sf turbo question
Yeah, i drive an EP
so do u have to get bigger injectors before u install this turbo kit?
basiclly what else do u need to buy that isnt included in what u get from stafford
Hail to the king baby
I'm wondering-- does this mean I can continue to fill up with 87 octane with water/alcohol injection? i was gonna run 93 octane until i was certain the alcohol injection was working OK, then go back to 87 (if it really is the same as using 120+ octane gas). i recall reading somewhere that running too high of an octane is bad? any clarification is appreciated, thanks
I would avoid running 87 unless you feel like paying for a new headgasket (detonation)... Even factory FI cars always recommend the top octane available to you....
And higher octane will hurt nothing whatsoever...
BOOST JUNKY
Higher octane burns less rapidly. Its used on hgh compression or F.I. applications. The lower the octane the faster it burns...but the likelihood of detonation increases (under heavier loads of high comp. or boost, etc).
In other words though....a really high octane wouldn't be beneficial to an n/a car for which a regular octane rating is recommended. You might actually lose power.
Octane is like this: The higher it is, the colder it burns. the colder your engine is running, the harder you can push it (more boost) Alcohol injection sprays a 50/50 mix of water and alcohol into your engine, the alcohol is bunred off and the water is ejected through the exhaust as steam taking the heat from your engine with it (making it run cooler so you can boost higher)
~nick~
~nick~
I spray 100% methanol. My car runs lean w/ alch&water. It made alot of diff when I switch to methanol. I might do a dyno run on pure methanol and compare. From my butt dyno it feels like at least 15-20hp difference.
Thats probably not the best idea.. seeings how the water is used to cool the engine. The methanol might make more power but it wont get rid of heat like the water will. Hopefully you wont roach your motor.
~nick~
~nick~
Originally posted by C2i0v0i1C
i dont even know where to begin with that statement............
Thats cool and all.. but that does not have the cooling ability of the water mix because the water takes the heat out of the engine through the exhaust. So dont be suprised if you try to crank up the boost and it doesnt work out that great.
~nick~
~nick~
~nick~
~nick~
