Altezza grill install
Old Sep 25, 2003
2k1civicExCoupe's Avatar
2k1civicExCoupe is an unknown quantity at this point
i've searched for the install but everyone says to remove the front bumper and put it in. how do u actually
"take off" the original grill and "put in" the altezza grill?? also about how long will it take to install?? thanks.
Old Sep 25, 2003
nme3's Avatar
JDM wannabe
couple of screws and those clips hold in the original grill all visible and shouldnt be to hard to spot, and then the grill should slide out. as for instal time most of it would be dedicated to taking and putting back on the front bumper as swapping the grill only takes minutes, for me it was around 15-20 minutes altogether.
Old Sep 25, 2003
Entropy's Avatar
Entropy is an unknown quantity at this point
then you have the option of cutting the old plastic cover so that it fits and can go over the hood latch, me personally, i just left it off
Old Sep 25, 2003
civicvtec1ps's Avatar
Search and Learn
http://www.7thgencivic.com/modules.p...howpage&pid=42
DIY for removing front bumper. grill is held by couple screws. you will see once you remove front bumper
very easy install
Old Sep 25, 2003
XxSoVeReiGNxX's Avatar
Is easy fella. There are four visible black button/clip things at the top on the black plastic radiator part behind the grill.
Once you get the bumper off, the stock grill is attached on the inside of the bumper by 2 screws at the far ends of the grill, and four screws/clips (I can't remember which) on the bottom rim of the grill (the are on tabs that stick out).
I did the whole swap with the "Headight Clearing" DIY instructions, in less than an hour.
Old Sep 25, 2003
the back of the altezza grill is almost the same as the OEM grill (grill to bumper-wise). For the radiator cover, altezza grills are only compatible with sedan (4door) radiator covers.
Come to one of the local meets, and a lot of members will more than be willing to help you out.
Old Sep 25, 2003
YS's Avatar
YS
YS is an unknown quantity at this point
altzza grill w/ 4dr radiator cover ...... clean
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
