whats an O2 simulator
Old Sep 16, 2003
BasicEssentials2k1's Avatar
BasicEssentials2k1 is an unknown quantity at this point
So what does this do....? and does it add HP...? also does anyone know a website that sells them for our cars....? please help me out
Old Sep 16, 2003
Voiceofid's Avatar
End Bringer
our vehicle have 2 o2 sensors, 1 before and 1 after the cat. the 2nd 02 sensor is to check make sure the cat is functioning correctly.
when you put a high flow cat in replace of it, or run a straight pipe, the after-cat o2 sensor will read malfunction to the catalytic converter. thus, throwing a code and check engine light comes on.
the o2 sim is there to prevent that from happening by fooling the o2 sensor that everything is working correctly.
how it accomplish that? i really don't know. maybe it changes the voltage of the signal from the o2 sensor back to the ecm.
Old Sep 16, 2003
HYPR DRV's Avatar
Since 1977
HYPR DRV will become famous soon enough
Um okay, you're new so I'll answer your question. The O2 sim is for people like me, who have replaced their catalytic converter with one that doesn't have the original oxygen sensor. It basically sends a message to the car's ECU telling it that the oxygen levels are normal. It SIMULATES an O2 sensor, which comes stock with the car. NO, IT DOES NOT ADD HP!!! All it does is send the correct readings to your car's computer. But if you have your stock cat, then don't even worry about needing one.
Old Sep 16, 2003
Voiceofid's Avatar
End Bringer
oh, it actually replaces the o2 sensor? my mistake, i never owned one, nor seen one, just heard of it.
Old Sep 16, 2003
HYPR DRV's Avatar
Since 1977
Well, if you replace your stock cat, then typically there is a hole where the O2 sensor should be. Since, you have a new cat (usually a hi-flow resonator, like with the HP Racing Header), there is no sensor anymore. Something needs to send the right signals to the ECU otherwise the CEL will stay on and that's where the O2 Sim comes in.
Old Sep 16, 2003
bamb00's Avatar
Here's a MIL eliminator, dunno if it's the same thing but it works the same way.
Old Sep 16, 2003
Legxcy's Avatar
Legxcy is an unknown quantity at this point
I am lost like everyone else.
Old Sep 16, 2003
Voiceofid's Avatar
End Bringer
a o2 sensor sends a voltage to your computer as a signal. the o2 simulator simply "simulate" that signal
Old Sep 17, 2003
ohhhhhhhhhhh
Old Sep 17, 2003
onebuddha1's Avatar
onebuddha1 is an unknown quantity at this point
i have tha MIL eliminator... its works.... tha wires connects inline of tha o2 sensor
Old Sep 18, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
dood.. thats just a resistor... basically an o2 sensor works by producing a current for the amount of o2 that is in your pipe... o2 simulators dont completely replace the o2 sensor because there are 4 wires that go to the ecu.. or something like that, one registers how much o2 is in the pipe at the time(voltage) and the other registers heat from the o2 sensor... my o2 simulators that im starting to make is a little box that splices DIRECTLY onto the ecu ive driven with it in my car for a week now and no signs of the check engine light for that, and the air/fuel mix is still fine(from the smell of the exhaust fumes)
if u need an o2 sim, PM me
Old Sep 23, 2003
jasonerice's Avatar
jasonerice is an unknown quantity at this point
Hey dude I noticed that nobody said where you could buy one so here it is. bigjoshracing.com sells them for sure cos I just bought one with a header and highflow cat for 360 bucks shipped so try them.
Old Sep 23, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
With the HP Race W/Hi flo cat there actually is a bung for the second o2 sensor. And i've had mine installed for almost 2yrs and it only threw a CEL untill i reset the ecu 2x. No problems since.
Old Sep 23, 2003
HYPR DRV's Avatar
Since 1977
So you never installed an O2 Sim? Just reset the ECU 2 times and the CEL is off? Oh, and define "bung". Cuz' I get a whole different interpretation when you mention that word.
Old Sep 23, 2003
WannaBFast's Avatar
well for some of us.. the light never shuts off.. so i went to teh extreme and built an o2 simulator.. im gonna be making a few more so i can make a few extra $$ on the side.. PM me if you are interested.. i already have abour 5 ppl interested in these, i have it in my car, been about 2 weeks, no check engine light, and gas mileage is slightly up
Old Sep 24, 2003
xblkcivicx's Avatar
Basicly what you have in mind, it's a hole for the o2 sensor to go in.
Old Sep 24, 2003
WannaBFast's Avatar
actually mine takes advantage of the heat sensor on the o2 sensor.. you just gotta splice this into the power, and connect the box that i made into the o2 sensor wire.. and detach the old one...
cleanride13
Aug 12, 2003 11:34 PM
2002vtecsir
Jun 21, 2003 06:14 PM
orion_squall
Apr 18, 2003 08:35 AM
R3DL1N3
Mar 17, 2003 02:10 AM
spike
Feb 21, 2003 03:46 PM
