DIY: Make SRS light gone without airbag install ( racing steeringwheel )
Old Sep 16, 2003
pecX's Avatar
pecX is an unknown quantity at this point
To remove the stock steering wheel refer to this forum http://www.7thgencivic.com/forums/sh...ight=srs+light
*** Dont forget to Disconnect battery for 30 min (for sure) before take the srs harness off hit brake pedal 1 time ***
Name:	resize of dscf0011 copy.jpg
Old Sep 16, 2003
pecX's Avatar
Put the Resistor 2 Ohm into each pair of srs harness pin as shown on pic.
Myself put 2.2 Ohm bought from Fry Electronic work Fine
Name:	resize of dscf0017 copy.jpg
Old Sep 16, 2003
pecX's Avatar
Then tape it . And pray
Name:	resize of dscf0018 copy.jpg
Old Sep 16, 2003
pecX's Avatar
Now you can replace the steering wheel with the racingwheel or JDM steering wheel.
Then reconnect battery . Pray.........
Name:	resize of dscf0024 copy.jpg
Old Sep 16, 2003
pecX's Avatar
Turn your key to ign2 for test. It's gone without airbag install (^0^)
Name:	resize of dscf0019 copy.jpg
Old Sep 16, 2003
pecX's Avatar
If you follow these steps RESET SRS is not need (^_^)
remember disconnect battery 10-30 mins hit the brake
So enjoy your JDM DC5 wheel ,momo ,spaco ,nardi
Old Sep 16, 2003
pecX's Avatar
I have this idea from Mugen Boss canelation clip But it's for Jdm srs harness. It's work
Old Sep 16, 2003
vvii's Avatar
vvii is an unknown quantity at this point
That's a cool DIY man....... great job
Old Sep 26, 2003
Drivetofast's Avatar
Supercharged k20a3
Drivetofast is an unknown quantity at this point
Why did you do that there is no point when you get a JDM wheel, it has an air bag and will work, so all you are doing is making your air bag not work. i would only do that if i had a wheel with no air bag and harnesses and racing buckets
Old Sep 27, 2003
CapYoda's Avatar
Escaped Convict
i believe although it has an airbag.. it wont just hook up and work.
gotta take it to the dealer to have them program it.
and have them charge u an arm and a leg.
its not plug and play, last I check.
Old Oct 1, 2003
Supercharged k20a3
I worked for a honda dealer the only thing that needs programing is the OBDS unit the airbags are plug and play.
Old Oct 1, 2003
Connie's Avatar
So your point is this is only a really good DIY for the other 4 or 5 wheels he mentioned...
Old Oct 1, 2003
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
whats a obds?
Old Oct 1, 2003
skipbarber's Avatar
on board diagnostics..
Old Oct 2, 2003
Supercharged k20a3
its the ocupent position detection system, it's on the left side of the pasinger seet, if you guys want anything related to srs msg me because i have acses to the honda interactive network
Old Oct 2, 2003
R1Style's Avatar
This is great... we should put this in the DIY section.
Anyways, what does hitting the brake pedal do?
Old Oct 2, 2003
Connie's Avatar
Probably to totally discharge the system from electric current....just a guess.
Old Oct 7, 2003
gtracing's Avatar
TeLLy is my daddy
gtracing is an unknown quantity at this point
is it 2.2 ohms or 220 ohms or 22000ohms? cause i don't think they make 2.2 ohms, what colour is the third band? is it orange or brown?
Old Oct 15, 2003
pecX's Avatar
It's 2.0 Ohms.
The JDM air bag is one stage airbag so it come with 2 wires.
But USDM airbag is two stage come with 4wires .
Yes you can use the JDM airbag and it's work but the light still on because the srs unit not found the 2nd stage.
I beleive If you connect jdm airbag to the car and put 2 ohms resistor on the other pair of wires the light should be gone.
Old Oct 19, 2003
gtracing's Avatar
TeLLy is my daddy
well i have an acura 1.7EL, cause i'm from Canada, but it's basically the same as a 7thgencivic, i did all that, i bought a 2.2 ohm resistor and connected it the way you showed...but the srs light is still on, after i plugged it in, do i have to disconnect my battery again and reset the ecu? because we tried many different types of resistors, and none of them worked cause we didn't have the right one's...but the battery was still connected when we plugged them in, we just unplugged the battery for taking off the steering wheel....i don't have an aftermarket airbag, i only have a momo jet steering wheel w/o airbag...
Old Oct 19, 2003
cheukkin's Avatar
cheukkin is an unknown quantity at this point
I'm a 1.7el owner and I did that DIY with no problem for that just using the 2.0 ohm resistor then plug in, at the beginning the SRS light still on then I reset the SRS again(in the DIY section), the light vanished!!! Thanks for the DIY!
Old Oct 20, 2003
gtracing's Avatar
TeLLy is my daddy
reset the srs? but u gotta buy those wires and stuff right?
Old Oct 20, 2003
gtracing's Avatar
TeLLy is my daddy
and hey, if u have a 1.7EL, u should join clubel.ca
Old Feb 18, 2004
pecX's Avatar
any 2.0 Ohms from electronic store would work.
Old Feb 18, 2004
dalaw's Avatar
Bone Stock!
Why would you guys give up airbags for a racing steering wheel?
Old Feb 18, 2004
pheaton's Avatar
A descendant of 2k1civic.com
This prevents the light from turning on. . It wont shut it off if it's already on. To shut it off after it's already on, use this:
DIY Reset SRS Light
Old Feb 18, 2004
pheaton's Avatar
Maybe racing steering wheels taste good and if you get in an accident at least you'll have something to eat?
voblak2
20
May 4, 2023 02:08 PM
ChristinaVHH
May 10, 2015 03:51 PM
bo_red
Transmission
May 3, 2015 09:14 PM
bsmiley
Apr 27, 2015 01:27 PM
aZnVoYCe
Dec 7, 2001 12:41 AM
