Tuning ?
Old Sep 11, 2003
UnOrthodox9546's Avatar
UnOrthodox9546 is an unknown quantity at this point
Question Tuning ?
I went and talked to a shop yesterday about installing my tuebo and they said they would install it but they wont tune it. What tuning is required and will i need to purchase anything else to tune it? (I have a greddy FATT and a greddy profec b boost controller ) ???
Old Sep 11, 2003
andyman97's Avatar
Turbo Guru
Basically tuning your fuel setup so you don't run lean or too rich. Boost controller shouldn't be too tough, just read your maunuals.
Old Sep 11, 2003
What could i buy to tune my fuel setup?
Old Sep 11, 2003
C2i0v0i1C's Avatar
SuperMODrizd
greddy makes the emanage.......apexi makes that safc
Old Sep 11, 2003
K THANKS FOR ALL THE HELP GUYS! I WILL GET THE E-MANAGE ASAP!
Old Sep 11, 2003
C2i0v0i1C's Avatar
SuperMODrizd
the emanage can do a whole lot more than just tune ur fuel, if u need to just tune ur AF get the SAFC or if u have vtec get the VAFC, due to the price differences, if u get the emanage u have to have the program to tune it and the cable to plug into the back of a laptop
Old Sep 11, 2003
I HAVE A LAPTOP I CAN USE FOR THAT. ALSO WOULD I NEED TO BUY THE "Optional GReddy Pressure Sensor and Pressue Harness" ?
Old Sep 11, 2003
C2i0v0i1C's Avatar
SuperMODrizd
yea, u need the program too to setup the maps
Old Sep 11, 2003
where do i get maps for our cars?
Old Sep 11, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
They are all dependant on your setup. Fuel delivery, injector size, pump, blah blah blah.
Also, if you are tuning your fuel yourself.... you should invest in a wideband O2 sensor and whatever. Bosch maks some. HKS makes one for around $500. It's a knock and wideband O2 monitor. It's nice. I want it.
Old Sep 11, 2003
I wouldnt tune it myself probably. I have stock injectors pump and stock everything except i will have the regular sf kit.
Old Sep 11, 2003
andyman97's Avatar
Turbo Guru
With that kit, you really don't need anything. When you install it, you install a vacuum line that allows the pump to read boost and adjust fuel pressure accordingly. There would be little to no tuning involved. Get a fuel pressure gauge and a good a/f gauge. Gadgetseller actually modifies autometer gauges to make them more accurate at reading air/fuel mixtures and if you already have an a/f gauge, you can send it to them and have them modify it for dirt cheap.
Old Sep 11, 2003
Ok, ill look into the gauges. What should i look for with the a/f gauge wheni get the kit installed?
I also have a boost gauge, oil pressure and egt gauge.
Old Sep 11, 2003
andyman97's Avatar
Turbo Guru
Fuel pressure and a/f gauges will suffice just fine. With the a/f gauge, you want to be in the stoich, that's between lean and rich. The thing to know about these gauges is that they only read under high throttle and when the o2 sensor warms up.
Old Sep 11, 2003
Ok, Thanks again for all the help !!
UltraHDGames
Jun 8, 2016 05:16 PM
shadowfist
Oct 18, 2015 02:38 PM
beanhead
Sep 24, 2015 12:04 PM
Zedoc
Engine Swaps
Sep 12, 2015 04:27 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
