can you pull the gov...?
Old Sep 9, 2003
BasicEssentials2k1's Avatar
BasicEssentials2k1 is an unknown quantity at this point
when im on the freeway my car cuts at 130 it like still wants to go but just kinda stops feeding it fuel or soming then goes back to 125. Is there anyway you can take that thing out....? i dont care if its illegal i think it would be rad to hit 140 charging the I-5 toward SD.!
Old Sep 9, 2003
muzhik's Avatar
where ghetto dogs come for the lowdown on deals...
muzhik will become famous soon enoughmuzhik will become famous soon enough
How high are you RPM's when you going 130???
Old Sep 9, 2003
umm im not sure but i swear to god im not lying i thinks its around 5. i have that tornado air and it works so freakin good like u dont really notice that thing on city streets but i totally recommend it on the freeway it totally pushes air. but anyone know how to take off the gov.....
Old Sep 9, 2003
civic-king's Avatar
civic-king is an unknown quantity at this point
your going to get locked up.......(thread)
i just posted this under "spanked by eclipse"
Old Sep 9, 2003
civic-king's Avatar
they say it's illeagal, and the goverment will shut this website down if any posts are made about cutting the governor....
Old Sep 9, 2003
dude no way well im so sorry dude thats crazy i didnt mean a gov...! wow what a mistake i was talking about that damn battery hold down....:/
Old Sep 9, 2003
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
what is tornado air?
Old Sep 9, 2003
civic-king's Avatar
that's a good recovery..
have you used a spiral max?
how do you think the tornado compairs? (if you tried it)
i think i'm going to buy both, T. by the filter, SM by the throttle body!
Old Sep 9, 2003
sprial max huh is that were u put it between your throttle body....?? well iv learned this ... that if they both spin the air the right way your set and ur stoked but if one spins clockwise and one spins counter... ahhh hahah ur F.in screwed just make sure they both spin the same imm almost positive it does! but tornado really works alot
Old Sep 9, 2003
Elite's Avatar
Elite is an unknown quantity at this point
to take off the gov. rip out your engine and run as fast as you can, kinda like flinstones.
Old Sep 9, 2003
civic-king's Avatar
what does that mean?
do you know how to "take off the governor?"
Old Sep 9, 2003
taz757's Avatar
If I'm not mistaken, we have an electronic govenor. This would mean that you need to have your ECU reprogrammed to remove or raise it. I do know that you can actually remove the rev limiter on our car, but why you'd want to do that, I don't know. You won't get any more power out of a crappy D17 @ 8000 RPM.
Old Sep 9, 2003
ya i called up a local speed shop and he said the gov is in the ECU so you would have to get a new custom ECU $$$$$ or get ur ecu programed for track use only (ya right track us only) he didnt know were to get it done
Old Sep 10, 2003
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
I've seen this thing in magazines called a Governor Bypass... Its like $50 or something, dunno if its legit.
Old Sep 10, 2003
Drnknmnky13's Avatar
Chuckle......OK kids here we go. The car is speed limited by the ECU. You can either go with an after market one, or get yours flashed. Those are your only two options. As for the tornado HAAAAAAAAAAAAA. You MIGHT notice a difference if you had a carbureted car since the mixing happen in the carburetor and the tornado would help to mix the fuel. But you have a fuel injected car there Einstein. Meaning you swirly air just goes into the cylinder like non swirly air where the fuel is then injected in. If you think you notice a difference then you "butt dyno" needs recalibrated. Maybe you need more stickers.
Old Sep 10, 2003
EvilGenius's Avatar
EvilGenius is an unknown quantity at this point
hmm, someone got sweated :-x
Old Sep 11, 2003
Slumpert's Avatar
Slumpert is an unknown quantity at this point
Erm, couldn't you just put a switch on the "speed sense" wire and shut off the ECU's ability to see the speed?
Course maybe the ECU will think "humm we were going 125 and now we are going 0, AIRBAG DEPLOY"
Slump
Old Sep 11, 2003
Chocobo's Avatar
Chocobo is an unknown quantity at this point
Slump
hahahhahahaha airbag deploy.....
that would be sooo funny
Old Sep 11, 2003
blckpwdr's Avatar
blckpwdr is an unknown quantity at this point
how are you going that fast without hitting redline? my car goes about 120 at 6900 rmps.
Old Sep 11, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
120 at 6900...You must have an automatic....I got an ex, 5spd and I've hit 130.
Old Sep 11, 2003
cdmx's Avatar
you know someone else asked a similar question and a mod goes "ILLEGAL, Locked" i mean cmon....is he gonna lock all the kamikaze, HP, Topspeed header threads? they are illegal too.........................................
Old Sep 11, 2003
blckpwdr's Avatar
i have a five speed. it has a 43? final drive
Old Sep 12, 2003
clownprince's Avatar
Ricerus Maximus
OWN3D
I had to tell my friend this same thing last weekend. He still didn't believe me. And butt dynos aren't very reliable.
Old Sep 12, 2003
CivicHX01's Avatar
butt dyno is never reliable... its called the placebo effect, you know you installed something so you are gonna expect gains, so your mind pretty much makes up the gain (cuz you don't wanna be dissapointed)... butt dyno would actually be more accurate if you never knew about the mod in the first place...
Old Sep 12, 2003
civic-king's Avatar
this guy doesn't know what he's talking about!!
tornado/spiral max DOES work on a fuel injected car. the "swirly" effect pulls air down the air tube going into the throttle body. i've been to an expo where this was demenstrated.
the guy had a clear tube, and their was a small perpellar that was suspended on a nail in the bottom of the tube. it was hooked to a air flow meter. when the vaccum was turned on, the perpellar hardly even spun. the cfm's were like 125. when the tornado was applied to the top of the tube, the perpellar started spinning like mad!! the cfms jumped to like 700!!
so don't listen to the drunk monkey, he's full of it!!!
these things work, and they add air flow and fuel atomizing propertys that surpass that of just a air pipe.
worth the money!!(in my opion) imp:
Old Sep 12, 2003
xblkcivicx's Avatar
You are correct, if it actually worked and gave you proper swirl it would increase your cfm. BUT!! think about how awesome it will be when one of those blades break off and chews your valves/pistons to hell, and spits it out your tailpipe... Now that is what they dont tell you.
But hey think of it this way...you'll look cool shooting sparks out your tailpipe!
Old Sep 12, 2003
civic-king's Avatar
why would the fin break off? all the air pushing against it?
i'm sure they thought of that when they built the thing, and besides it's stainless steel.
i don't think it'll have any problems.
Old Sep 12, 2003
xtiszx's Avatar
Cracka
xtiszx is an unknown quantity at this point
Yea, hes also testing it on a nail, and friggin pipe, not a d17 motor, it might work so so, but you dont feel anything, its called power of suggestion, you think its adding power cuz they say it is, If you want to see my point, and a few other members point, go get it dynoed with and with out that POS mod, you might see 1hp gain if that, or maybe even lose power. i think theres enought members on this site, that know more then you could image about cars, and they would all agree,
Old Sep 12, 2003
civic-king's Avatar
the nail had a prop on it, so you can see the movement of air in the tube. i think i will get one and dyno test it. (yeah right. i'm not spending the money to show you what a dumbass you are) and there is a change of HP in the positive. i have 4 friends that have purchased the spiral max, and i've ridden in all their cars/trucks before and after installation. let me tell you,(smart guy) it made a noticable difference when the throttle is mashed!! but talk all the crap you want, you always do. you never have anything good to say, just negitive input. (or is it output) don't buy the "POS mod," i wouldn't want you to change your high intelect and superior knowledge of cars.
Old Sep 12, 2003
syndrome's Avatar
syndrome is an unknown quantity at this point
damn, guess it doesn't take a high post count to 0wn ppl on here
