Rsx Type S Seats..?
one of the bolts doesnt line up in the front
the rear bottom goes right in
i dunno about the rear back
you'll be paying for the seats too. they're almost as much as s2k seats right now
they dont bolt in there is a lot of modification to the rear and the rear seats of the RSX are lower than the Civic so youll have thet rear Civic deck sticking up farther than the seats not to mention that the rear RSX seats dont bolt up so you need to modify a bracket to fit the Civics. The RSX rear needs to have the foam cut out and restitched and covered to make it fit since the split is 60-40 on the RSX and 50-50 on the Civics. Its not an easy job to do but it can be done. The fronts dont bolt right in there is some mods to those as well but not as much.
No im not but i talk to Greg on a daily basis and i was gonna do the same swap. It cost about 1k for the seats front and back. As far as the install costs he has a hookup so it didnt cost him much. My advice is to get the fronts only and then wrap the back in the same leather. Im doing the S2k seats and wrapping the rear seats in S2k leather.
if your doing it on your own prolly about 100 to 200 installed and everything. Thats including the rear seat conversion. If your only doing the front then just the cost of the seats then
Originally posted by tp4r.whoooo
well can u ask him when u have time azure b/c that's your friend..heh if u dont mind
.Is that 6-8 hundred for the front and back seats?
Originally posted by RedDragon333
. . . since the split is 60-40 on the RSX and 50-50 on the Civics. . .
. Registered!!
Originally posted by Azure
I believe it's the other way around
. I JUST finished swaping front RSX seats into my 03 civic coupe. It works, but requires a bit of muscle, a hammer, a dremmel or drill and a crecent wrench.
The front tabs have to be bent out a bit (use a crecent wrench), and the holes on the back tabs have to be enlongated about 1/4" to the rear.
The carpet under the tabs should be cut out a bit more than it is already.
Tighten the rear bolts about half way, then get a big heavy guy to bounce on the seats, this pushes the front down enough put the outside bolt in, then you need to use the claw of the hammer as a lever to move the front inside rail in abit from the center console, so the bolt lines up.
2 hours
2 guys
lost count on beers
2 hours
2 guys
lost count on beers
PunX
Sep 23, 2015 10:45 PM
