Rsx Type S Seats..?
Old Sep 8, 2003
tp4r.whoooo's Avatar
tp4r.whoooo is an unknown quantity at this point
Rsx Type S Seats..?
Would a full rsx type s seat front and back swap fit in an 03 black civic?
without buying anything extra or "making" it fit?
Old Sep 8, 2003
azure's Avatar
You'd have to modify a few things, I think. You can talk to Greg at hondawerx.com. He did it to his Civic. He doesn't have the car anymore though.
Old Sep 8, 2003
azure's Avatar
His previous car:
Kinda funny because now he has an RSX Type-S.
Edit: just found this on his site. . . here.
Old Sep 8, 2003
RoadRunner's Avatar
he even swapped the back seats ??
Old Sep 8, 2003
azure's Avatar
Yes.
Old Sep 8, 2003
oh..what kind of modifications would i have to do?
well can u ask him when u have time azure b/c that's your friend..heh if u dont mind
Old Sep 8, 2003
dragoon's Avatar
one of the bolts doesnt line up in the front
the rear bottom goes right in
i dunno about the rear back
you'll be paying for the seats too. they're almost as much as s2k seats right now
Old Sep 8, 2003
RedDragon333's Avatar
they dont bolt in there is a lot of modification to the rear and the rear seats of the RSX are lower than the Civic so youll have thet rear Civic deck sticking up farther than the seats not to mention that the rear RSX seats dont bolt up so you need to modify a bracket to fit the Civics. The RSX rear needs to have the foam cut out and restitched and covered to make it fit since the split is 60-40 on the RSX and 50-50 on the Civics. Its not an easy job to do but it can be done. The fronts dont bolt right in there is some mods to those as well but not as much.
Old Sep 8, 2003
are you the one that did the type s seats in ur ride? how much did it cost u in total
Old Sep 8, 2003
No im not but i talk to Greg on a daily basis and i was gonna do the same swap. It cost about 1k for the seats front and back. As far as the install costs he has a hookup so it didnt cost him much. My advice is to get the fronts only and then wrap the back in the same leather. Im doing the S2k seats and wrapping the rear seats in S2k leather.
Old Sep 9, 2003
so how much do you think it will run me on the top of ur head to do waht u told me to do..ima get used type s seats prolly around 6-8 hundred
Old Sep 9, 2003
if your doing it on your own prolly about 100 to 200 installed and everything. Thats including the rear seat conversion. If your only doing the front then just the cost of the seats then
Old Sep 9, 2003
azure's Avatar
Not exactly. It's just that I usually deal with him when it comes to purchasing car parts or whenever I have questions about my car .
Is that 6-8 hundred for the front and back seats?
Originally posted by RedDragon333
. . . since the split is 60-40 on the RSX and 50-50 on the Civics. . .
I believe it's the other way around .
Old Sep 9, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
wats greg drivin now?"
Old Sep 9, 2003
skipbarber's Avatar
an RSX type S...as mentioned in the third post
Old Sep 9, 2003
i think it was like 6 bills used for the front seats only =/
Old Sep 9, 2003
Entropy's Avatar
Entropy is an unknown quantity at this point
the website link in the 1st post explains all the modifications needed to install them
Old Sep 9, 2003
Entropy's Avatar
make that 3rd post
Old Sep 9, 2003
azure's Avatar
This (I hope he wouldn't mind me postin a pic of his car):
I want those ITR rims!!
Old Sep 9, 2003
my bad, i was in a hurry and the words were coming outta my head faster than i was typing them. Thanks for the correction bro
Old Sep 9, 2003
azure's Avatar
No prob. I do that too .
Old Sep 15, 2003
LiTtOaZn2nR's Avatar
LiTtOaZn2nR is an unknown quantity at this point
Would S2000 seats work cuz I love them....it's has a more aggressive look then then RSX seats...
Old Sep 15, 2003
RoadRunner's Avatar
yea they could fit with a lil bit of work, everybody at HIN in dallas had those in their civic's
Old Sep 27, 2003
petes97's Avatar
petes97 is an unknown quantity at this point
I JUST finished swaping front RSX seats into my 03 civic coupe. It works, but requires a bit of muscle, a hammer, a dremmel or drill and a crecent wrench.
The front tabs have to be bent out a bit (use a crecent wrench), and the holes on the back tabs have to be enlongated about 1/4" to the rear.
The carpet under the tabs should be cut out a bit more than it is already.
Tighten the rear bolts about half way, then get a big heavy guy to bounce on the seats, this pushes the front down enough put the outside bolt in, then you need to use the claw of the hammer as a lever to move the front inside rail in abit from the center console, so the bolt lines up.
2 hours
2 guys
lost count on beers
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
anubis62
Sep 27, 2015 12:56 AM
speedlever
Sep 24, 2015 07:18 PM
PunX
Sep 23, 2015 10:45 PM
