DIY - JDM HEADLIGHT QUESTIONS
Civicforums Junkie
ok...so ive decided on taking my oem headlight housings apart and painting the housings black...i have the sealant for re-sealing them and the high-temp black paint...i will be masking them soon and i will also be putting the amber lens back in to create the 'JDM look'...
the questions that i have are about the oem chrome housing:
would i need to 'scuff' it up first??
what should i use to do this??
thanks guys!!
thanks guys!!
Search and Learn
i didnt do anything. just used high temperature engine spray paint. about 5-7 coats. had no problem
i used newspaper to cover up turnsignal chrome part
would you hit it?
would you hit it?
Civicforums Junkie
really??
if thats true, then i have nothing to worry about
**can anyone else confirm this??**
EDIT: civicvtec1ps: what if i were to paint the signal / parking light areas and then reuse the amber piece??
Search and Learn
Originally posted by FALKEN
civicvtec1ps: did you paint the signal / parking light areas??
You can scuff the chrome if you want, if that makes you feel better, but there's no need. They're gonna be sealed from the elements and the paint seemed to adhere just fine.
I took out my amber lense and painted all of it blakc (I have a black car) and i didn't scuff it up, stuck just fine. Also, if you want to match the clear coat most closely get a glossy paint or clear coat the flat black, it looks dam nice when you're finished.
Reppin Stage 7
What I did with mine is just wipe it down with some acetone.. What that did was clean the surface and also etched the chrome a little bit.. I then painted them with High temp glossy black paint... I didnt mask anything and reattached the amber lense. Came out fine... Just make sure to let it fully dry cause when you try and attach the amber part you have to touch the painted surface and if you leave it wet it will mess up and leave finger prints... Here is a pic of the finished product.
Cleanly done. Very nice. I did my homeboi's lights, turned out better then I thought IMO then it should have. He left out the amber piece tho and just has amber bulbs.
Reppin Stage 7
XTREME2K2CIVIC: thank you!!
thats exactly what im trying to accomplish...
how bright does the signal light up??
I painted everything black on mine, parking lights area and turn signal too, didnt put the amber piece in, turned out just fine heres how that looks for another suggestion:
so some of you did it without masking anything off? hmmm, i've never taken my headlight assembly apart, so i'm not sure how it's assembled. if you don't mask, which chrome parts end up being painted black? parking and turn signal?
thanks
thanks Joined: Sep 2001
thanks
thanks Thread Starter
Civicforums Junkie
ok...so they are done and they look great......
buuuut, i used the heat-heat flat black and they look gunmetalish...im thinking about redoing them with a semi-gloss black so that they match the upper/lower grill...opinions??
Civicforums Junkie
i didnt like the high-temp paint because it came out looking gunmetalish...i sanded them down and applied some plastic primer to them, after that dried, i sprayed them with flat-black (3-coats)...they are done and look much better now
i also painted the mesh on the altezza grill because it was close to the lights and you could see a difference between them (i had to mask it off though because the lip is painted ssm)
thanks again.
thanks again.
NoobyKid
Jul 13, 2015 07:53 AM
Kyles24
Jul 12, 2015 09:15 PM
Jul 12, 2015 11:54 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
...it took me an hour just to disassemble them
