DIY - JDM HEADLIGHT QUESTIONS
Old Sep 8, 2003
FALKEN's Avatar
Civicforums Junkie
ok...so ive decided on taking my oem headlight housings apart and painting the housings black...i have the sealant for re-sealing them and the high-temp black paint...i will be masking them soon and i will also be putting the amber lens back in to create the 'JDM look'...
the questions that i have are about the oem chrome housing:
would i need to 'scuff' it up first??
what should i use to do this??
thanks guys!!
Old Sep 8, 2003
civicvtec1ps's Avatar
Search and Learn
i didnt do anything. just used high temperature engine spray paint. about 5-7 coats. had no problem
i used newspaper to cover up turnsignal chrome part
would you hit it?
Old Sep 8, 2003
FALKEN's Avatar
Civicforums Junkie
really??
if thats true, then i have nothing to worry about
**can anyone else confirm this??**
EDIT: civicvtec1ps: what if i were to paint the signal / parking light areas and then reuse the amber piece??
Old Sep 8, 2003
Search and Learn
Originally posted by FALKEN
civicvtec1ps: did you paint the signal / parking light areas??
i did paint parking light areas but i didnt paint turn signal areas.as you can see , look at pics i posted above
Old Sep 8, 2003
FALKEN's Avatar
Civicforums Junkie
were posting faster than we can refresh
lets do this in PM's
Old Sep 8, 2003
FALKEN's Avatar
Civicforums Junkie
has anyone painted the whole housing and then reattached the amber lens??
pics maybe??
Old Sep 8, 2003
fraga's Avatar
Wicked Moderatuh
You can scuff the chrome if you want, if that makes you feel better, but there's no need. They're gonna be sealed from the elements and the paint seemed to adhere just fine.
Old Sep 8, 2003
Scott2055's Avatar
Scott2055 is an unknown quantity at this point
I took out my amber lense and painted all of it blakc (I have a black car) and i didn't scuff it up, stuck just fine. Also, if you want to match the clear coat most closely get a glossy paint or clear coat the flat black, it looks dam nice when you're finished.
Old Sep 8, 2003
dragoon's Avatar
i did 2 quick coats, no scuffing, and it turned out fine.
Old Sep 9, 2003
XTREME2K2CIVIC's Avatar
Reppin Stage 7
What I did with mine is just wipe it down with some acetone.. What that did was clean the surface and also etched the chrome a little bit.. I then painted them with High temp glossy black paint... I didnt mask anything and reattached the amber lense. Came out fine... Just make sure to let it fully dry cause when you try and attach the amber part you have to touch the painted surface and if you leave it wet it will mess up and leave finger prints... Here is a pic of the finished product.
Old Sep 9, 2003
FALKEN's Avatar
Civicforums Junkie
XTREME2K2CIVIC: thank you!!
thats exactly what im trying to accomplish...
how bright does the signal light up??
Old Sep 10, 2003
Nodnero's Avatar
Cleanly done. Very nice. I did my homeboi's lights, turned out better then I thought IMO then it should have. He left out the amber piece tho and just has amber bulbs.
Old Sep 10, 2003
Reppin Stage 7
The signal and driving light are a little more dim but I mean still visible.. But you have to figure that now the light is flashing off of black instead of chrome so brightness will be affected but since you still have amber signals you shouldnt have any police trouble or anything like that ...
Old Sep 10, 2003
FALKEN's Avatar
Civicforums Junkie
thanks!!
Old Sep 10, 2003
Cat's Avatar
Cat
gl.
keep a bottle of rubbing alcohol near you just in case you mess up and need to take the paint off. it won't harm the chrome.
Old Sep 10, 2003
KeNsHiN's Avatar
LEVA
I did mine the same way, just painted no prep needed
Old Sep 11, 2003
FALKEN's Avatar
Civicforums Junkie
damn sedan housings ...it took me an hour just to disassemble them
Old Sep 11, 2003
RSDCivic's Avatar
RSDCivic will become famous soon enough
I painted everything black on mine, parking lights area and turn signal too, didnt put the amber piece in, turned out just fine heres how that looks for another suggestion:
Old Sep 11, 2003
hassoomi's Avatar
so some of you did it without masking anything off? hmmm, i've never taken my headlight assembly apart, so i'm not sure how it's assembled. if you don't mask, which chrome parts end up being painted black? parking and turn signal?
thanks
Old Sep 12, 2003
RoadRunner's Avatar
i didn't want to risk messin anythin up so i bought some blackhousing headlights cheap from the local shop i ride for
Old Sep 12, 2003
fraga's Avatar
Wicked Moderatuh
thanks
Yup, those parts will get painted. When take your lights apart, you will have 3 pieces. The outer plastic cover, the housing itself, and the chrome piece that covers the housing which goes inbetween the two mentioned earlier. The base housing never get's touched, just the middle chrome cover piece.
Old Sep 17, 2003
FALKEN's Avatar
Civicforums Junkie
ok...so they are done and they look great......
buuuut, i used the heat-heat flat black and they look gunmetalish...im thinking about redoing them with a semi-gloss black so that they match the upper/lower grill...opinions??
Old Sep 17, 2003
Scott2055's Avatar
I used a flat black paint and then put clear coat over them to shine them up, looks real nice.
Old Oct 2, 2003
FALKEN's Avatar
Civicforums Junkie
i didnt like the high-temp paint because it came out looking gunmetalish...i sanded them down and applied some plastic primer to them, after that dried, i sprayed them with flat-black (3-coats)...they are done and look much better now
i also painted the mesh on the altezza grill because it was close to the lights and you could see a difference between them (i had to mask it off though because the lip is painted ssm)
thanks again.
Old Oct 2, 2003
XxJDMCivicxX's Avatar
Post some pics!
Old Oct 3, 2003
Connie's Avatar
RSDCivic, you ride looks very nice, and props on the Headlights, thats how I am going to do mine and just put an orange or white turn signal in...
JohnnyBxo
Nov 12, 2015 03:04 PM
NoobyKid
Jul 13, 2015 07:53 AM
Kyles24
Jul 12, 2015 09:15 PM
Jul 12, 2015 11:54 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
