how do i properly hook up a 4channel bridged amp to a DVC sub?
ok here's what i have....
i have a 4 channel amp that is bridgeable to 100watts x 2
i have a 4ohm + 4ohm DVC sub
i want that amp to put as much power as possible into the sub
so i guess it'll have to be each voice coil will be hooked up to one of the 100watt bridge chanels?
so i'll have to feed the exact same line level signal into each 100watt bridge channel? the problem is getting the exact same signal on both bridge channels.... do i have to have the exact same frequency cut off and exact same power output? it's not easy to get it EXACT because the amp has analogue trimpots(variable resistor *** thingys)....
there's no way to fine tune it exactly unless i use an oscilloscope....
so do i have to get it exact? will there be damage to my amp or sub if it's off slightly?
the sub will take up to 300watts RMS...
the amp is an old MTX Blue Thunder Pro that I already have....
for the time being, i'm too cheap to buy a new amp. the MTX one is also a bit underated.
http://www.jlaudio.com/tutorials/wiring/index.html
http://www.jlaudio.com/tutorials/dvc/index.html
I know it is JL but you'll get the idea
thanks....
i found this...it was what i was thinking but how close does power output and the frequencies have to be?
http://www.jlaudio.com/tutorials/dvc/diffsignals.html
so i'm guessing i'll have to use a test signal and an oscilloscope to callibrate my outputs to be as close as possible?
else is there anyway to make my 4 channel amp into a mono amp?
Originally posted by turboslug
also, what are the consequences of having slightly different power input but the signals are still in phase?
will it make one channel work extra hard?
hmmm...for now, i'll prolly just lug out the oscilloscope and tune it as close as possible....
if it blows, i'll just fix it....
where can i get a test tone? i'm too lazy to lug out a sine wave generator..hehe...
h4ldol
Apr 24, 2017 08:16 PM
Hutch1051
Sep 29, 2015 09:20 AM
pilebuck13
Sep 21, 2015 10:45 PM
