rewired taillamps??
Old Aug 2, 2003
civic-king's Avatar
civic-king is an unknown quantity at this point
rewired taillamps??
hello!!
i have a question!
has anyone switched their brakelights with their turn signal?
i saw this and thought it was sweet!!
now i tried to do this myself, but when i switched them, i connected the parking wire and the brake wire together, then wired them into the turn signal........this was wrong!
it looked realy sweet when i turned the lights on, the turn signal (a giant 'C') looked sweet!!
heres the problem.........
when the brakes are applied, the front turn signals come on, along with the dash lights!!
this isn't the real problem.........the brake lights have two(2) fillements,(one for parking lights, one for brake) the turn signal only has one, hence at night, i don't have brake lights!!
one of my friends says that i can put a diode in the +line of the turn signal(now the brake/parking) this would stop the turn signal (front) and the dash lights from coming on due to brake switch, the problem is that i still have no brake lights!!
has anyone done this? any help would be...........well, helpful.
thanks
~the king (needs help)
Old Aug 2, 2003
skipbarber's Avatar
best bet would be to use relays, wouldnt it?
Old Aug 2, 2003
YS's Avatar
YS
YS is an unknown quantity at this point
i did it 6 months ago ............ but i don't have my car right now ........ she's @ the body shop
all you need to do is cut the the (+) wire (i forgot which one for the brake light wire) from the signal light and brake light and switch it (brake wire to signal wire and signal wire to brake wire) ...............and you do not have to cut the Black (Ground (-) wires) ....... THAT's IT
MAKE SURE you cut the right one ........ you can use voltmeter to test the right wire (hit the brake while you test it)
hopefully it help...............
so right now i have brake light on the top and parking/signal light on the bottom
Old Aug 2, 2003
civic-king's Avatar
does everyone buy euros? no custom work?
is anyone here an auto electriction?
Old Aug 2, 2003
YS's Avatar
YS
Old Aug 2, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
i have mine ENTIRELY switched...including eliminating the side light... but NOT gonna say how i did it... im a jerk like that, it looks TOOOO tight, ive NEVER seen another tailight that lights up like mine... SO RAW... ALL kinds of 7th gen owners ask me about it, and im like ... "tight, isnt it?".. and they are like, "how'd you do it?", and im like, "they're stock from australia"... gotta throw off the haters... MAYBE if someone was in a whole different state i would show em how... lets just say VERY VERY VERY VERY little of my lights are on while i have tailights on........
Old Aug 2, 2003
civic-king's Avatar
anyone else have any ideas??
.................anyone???
Old Aug 2, 2003
guamcivic2k1's Avatar
YoUnG N SuXsExFul
wonder if this works for the sedan..any ideas?
Old Aug 2, 2003
gipperkid's Avatar
gipperkid is an unknown quantity at this point
Hey futurersxswap post a pic of your tails at night so we can check it out.....also if any is interested I have a set of TYC Carbon Fiber tails I am looking to sell. Used for about 3 months and are in perfect condition.
Old Aug 2, 2003
civic-king's Avatar
alright.....
i thought about what YS said.......this would work, but it's not the effect i want. i want my 'C's (on the tail light lights; brake) to be dark, except on turn signal only! the squares to be parking and brake.
this is hard because the brake and parking light has two(2) fillaments.
as of now i have switched my parking light (wire) on the brake light, and switched it with my turn signal. (wire)
this resulted in half-of what i want.......the turn signal has become the parking light. ('C's are dark in the dark) the 'C's now light when the brakes are pressed, or when the turn signal is active.
i noticed that the signal flashes twice as fast also. (cool....i guess)
any one else have an idea?
Old Aug 2, 2003
civic-king's Avatar
whoa!..............
*caution*
i went out to check my lights, (night time here) and i noticed that the way these are wired, (parkig to turn, turn to parking) when you press the brake, wile the turn signal on, the turn signal is overpowered buy the brake light.(the turn signal uses the parking lamp) this should not be a problem........unless you are turning on a hill, .....in front of a cop...
good luck.......
if anyone has a theroy on the light change i am looking for, (brake and parking light where turn signal is, turn signal on 'c's only) please let me know.........
thanks,
~the king
Old Aug 3, 2003
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
futurersx, can we see the lights in action?? i also eliminated the side light, i hated that damn triangle. im gona re work mine, and possibly create a DIY for "the haters". haha.
Old Aug 5, 2003
NorrinRadd's Avatar
NorrinRadd is an unknown quantity at this point
When you did this did your signals blink faster (hyper) or remain at the normal stock blinker rate?
Old Aug 5, 2003
khmaitiger's Avatar
khmaitiger is an unknown quantity at this point
couldnt u just move the bulbs? to the different spots? or just cut off the harnness and put it on the place u want it ?or something like that
Old Aug 5, 2003
Dustman380's Avatar
Dustman380 is an unknown quantity at this point
just switch the blub still plugged in. don't go wiring **** when you don't need to
Old Aug 5, 2003
XtremeJM's Avatar
I did this like a year ago and so has CivicSouldja.
Old Aug 5, 2003
NorrinRadd's Avatar
True, but I'd like the brake light to be on as a parking light as well. So rewiring is necessary.
EM2661
Sep 11, 2015 06:01 PM
ek_rebuild
Aug 11, 2015 08:00 AM
kool-aid
Lighting
Jul 19, 2005 11:11 PM
PJG
Sep 29, 2003 12:05 PM
Rider
Jun 12, 2002 08:35 AM
