Eyelids
hey someone should try this:
get the regular eye lid they sell on online store, paint em black or gunmetal and put it on a gunmetal/black housing headlight. can u see the picture? it might look good.
i might try this actually. anyone wanna go first?
i got mine at RSversion.com ... the shop that put them on didnt glue them down that well..... about a month or 2 later i was driving on the highway and 1 blew off.... lol i got tired of the winking car, so i just took the other one off.. .. ah well.
eyelid
hey g_50b:
sorry I never got back to you but i never even got your PM. I don't know when you PM'd
me but a while back I had PM's disabled so people couldn't get to me.
But either way, to answer your question those eyelids on my car are just vinyl that I had left over from my visor. In order to shape them to the curves of the headlight it takes a heatgun and a little patience. first, cut the shape you want, wet the headlight, peel the vinyl, wet both sides of it, place it on the headlight and as you pull evenly, push out any air bubbles with a credit card...you can use a library card if you don't have credit..=} and then using the heat gun and still pulling on the outer edges of them, you'll see that the vinyl will start to 'give a little and you can lay it right over the bump of the turn signal light. then just bend it over the edges, cut off the excess and wipe the headlight dry.
the advantages of using vinyl are: it is practically free, just vinyl, you can shape it to cover more or less of the headlight, you can take them off within seconds, on a hot day and do them over for a new look within 15 min. best off all, you can have eyelids that no one else has.
imp:
if you got any other Q's let me know. my PM should work now...
imp: if you got any other Q's let me know. my PM should work now...
i am experimenting them using aluminum and wrapped in fiberglass. I started with just plan aluminum trim eyelid, but they look too thin for me. doesn't seem to have the texture, so i gonna try to wrap those in fiberglass and see..
my friend got me a set off ebay, i just got them back from the painter.
http://mywebpages.comcast.net/exedotbat/eye.jpg
Search and Learn
i didnt want to use vinyl
vietstylez
Mar 17, 2004 09:01 AM
