LOL...$2 for 20 more HP you have 2 see
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2425505178
every go out and buy this...2 buck and it adds 20 HP
...lol....
...lol.... Thread Starter
ok does anyone know where that resister goes cuz I'll roll to radio shack and pick one up just for the hell of it,,,i guess it couldnt hurt if he's got good reviews right....
nut to buy off of ebay and get jiped ..i would feel like a sucker for somthing so dumb...lol
common sense isn't so common i guess...
The resistor, as any resistor does, simply resists the oxygen sensor into thinking that it has adequate air flow. By doing so the ecu tries to increase the airflow causing the fuel to increase and the engine to burn harder...hense more power.
HOWEVER, this WILL cause the cat, which is meant to catch harmful emissions, to work harder, at a faster rate then intended and with time it will clog and most likely damage a major engine component before you realize it did.
This of it as a very mini F I. If you don't know what F I is and you still want to buy the chip, I feel for you...
As in any FI the engine needed to be upgraded, pistons, cams, injectors...although this is not that major the damage and wear and tear of an engine will be increase and will cause a stock engine to break down on you
Otherwise why whould he state:
Will this void my warranty ???
NO this will not void out most warranties. If you have a very strict underwriter on your warranty you can undo this mod in less than 5 minutes. You can even Re-Install later. This leaves no trace of any modification.
now why would anyone want to undo a mod that does not damage an engine..?
common sense people...but to each his own i guess...
very nice....but where does it go...just for ***** and gigles i orderd it...lol this should be good, I' think I'll post a diy on it...lol..
hey it couldnt hurt the car anymore then my 50 shot of NOS right...
