Thinking about trying something new...
Old Jul 28, 2003
fonto's Avatar
The LA Clipper
Question Thinking about trying something new...
I was thinking about trying something new...I made the ports on my box pretty easy to switch in and out. Anyway, I was thinking about porting my subs to 35 hrtz. My question is where should I set my subsonic filter if I port to 35 hrtz? Is the 33 hrtz subsonic filter a good choice for subs tuned to 35, or should I try something lower? Could Shivas even handle being ported to 35 hrtz?
I basically want to see how loud my subs can get and still play music sounding good driving everyday.
Old Jul 28, 2003
tbone323's Avatar
tbone323 is an unknown quantity at this point
the best way to determine this freq is to use a box modeling program. I belive winISD will do this. Look at the cone excursion vs frequency plot. You will see the cone excursion drastically rise at freqs lower than your tuning frequency. Just find the Xmax spec for your drivers and play with diff subsonic crossover points to where you get max output but stay below your Xmax.
goodluck
~Tbone
Old Jul 29, 2003
alex053's Avatar
bass box pro 6 does this quite well.
Old Jul 29, 2003
LudlamTheory's Avatar
i boogie for the raindrops
i had a shiva ported at 35 once... try it out...
what are yours ported at?
Old Jul 30, 2003
fonto's Avatar
The LA Clipper
22 hrt with a 20 sub sonic
Old Jul 30, 2003
fonto's Avatar
The LA Clipper
Where can this be found?
Old Jul 30, 2003
well, as you said ports are easy to toy with. try going up to 30ish with a 28 hz subsonic. should give you a little spl boost. if anything you can keep a few ports laying around your house to interchange.
if you ever feel like seeing what a nice spl burp sounds like make a set of ports for 40 or so. i woudlnt tune any higher with a shiva
Cyborg Ninja
20
Jul 11, 2022 03:44 PM
Dangerousjordan
Jul 23, 2015 11:11 AM
97-DX-Lover
Jun 14, 2015 06:07 PM
zaboomafoozarg
May 30, 2015 09:21 AM
crowtoo
May 11, 2015 06:50 PM
