Help My Car Wont Start!
Old Jul 28, 2003
PsshH's Avatar
PsshH is an unknown quantity at this point
MY ****ING car wont start!.....i dont know whats the problem. i smell gas coming from the valve cover and the spark plug cover. there is no leak. i have a ex turbo charged civic. no fuel done though. thats probably my problem. but any way if any one can give me some help. like what they think it is or what i can get to fix it. i know its not the batterie so dont tell me that or the alternator or the starter. the key turns and it makes that noise when your car dies and your trying to start it. damn it ! help!
Old Jul 28, 2003
iamboo's Avatar
Retired - SoCal FI Mod
first of all... chilll...
is it a custom turbo setup or is it a kit??
Old Jul 28, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
how long was battery disconnected?
your immobilizer may need to have some reprogramming
needed to your keys
Old Jul 28, 2003
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
very true
someting might have triggered the immobilizer
what were you doing whenthis happened to your car?
Old Jul 28, 2003
Green Civic's Avatar
Were you trying to start from cold or hot (not running or running)?
Old Jul 28, 2003
evol's Avatar
evol is an unknown quantity at this point
simple but might have been over looked.... if its an auto... is it in a gear ?
Old Jul 29, 2003
GanariGuY's Avatar
GanariGuY is an unknown quantity at this point
Try disconnecting the battery for awhile roy..... or step on the clutch all the way....... u dunno sumtimes that happens....
Old Jul 29, 2003
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
more info please. does it turn? does it sound like its fuel starved or does it sound like theres no spark what so ever? in other words, what happens exactly when you turn the key. it could be something as simple as a drained battery, possibly ran out of fuel (its happened to many people), or maybe your injectors are shot.
Old Jul 29, 2003
CivicHX01's Avatar
hmmm.... he hasn't answered, maybe his car started by now... its been 2 hours since he posted...
Old Jul 29, 2003
skipbarber's Avatar
might be a main accessory fuse. its happened to me, everything turns on, but when you turn the key to start nothing happens. check the fuses under the hood.
Old Jul 29, 2003
Is this guy going to answer?
Old Jul 29, 2003
NeonImpact's Avatar
Forum Sponsor
i dont think so...
Old Jul 30, 2003
PsshH's Avatar
sorry you guys...i think my injectors might have gone bad.....damn i dont know..when i turn the key it gives me a sound like if you stalled
i know its not the battier because i also tried to jump start the car...and that didnt work......****!!!!.....oh also the check engine light is on now..yeah sorry again you guys for not answering....i have been so busy with work and ****......i think i am gonna tow my car to a shop and see if they can check it out...
Old Jul 30, 2003
alienmeatsack's Avatar
alienmeatsack has a spectacular aura aboutalienmeatsack has a spectacular aura about
that sucks... hope its nothing too serious.
only time i had a problem starting my car was after I spun out at the track and the engine and it's fluids got sloshed around real good. it started fine a bit later.
goodluck
Old Jul 30, 2003
jedi's Avatar
jedi is an unknown quantity at this point
There was a tread about this a while back , and was it some kind of gas purge valve or something like that?
I had a 90 Accord and until I sold it in April half the time it would start and every time I got gas would have to leave it running, if I shut it of I`ed have to wait about 20 min. before it would start. And nobody could fix it , not even the dealer ( I still have credit for paying and not having found the problem !! )
I hope my new Civic starts , at least if at some piont it does`nt , I`ll have them check that valve.
jedi
Old Jul 30, 2003
PsshH's Avatar
well the ting is it didn't start after 20 minutes...muahahahaha.....its going in the shop tomorrow so i will post for any updates....thanks to everyone on 2k1civic.com for there help and all...thank you, you guys!
Old Aug 3, 2003
BLCKOUT's Avatar
BLCKOUT is an unknown quantity at this point
this isn 2kcivic.com
this is 7thgencivic.com :-)
Old Aug 3, 2003
pheaton's Avatar
A descendant of 2k1civic.com
Check for the blinking green key (immobilizer light) on the panel. If it's blinking something has triggered the immobilizer. It happend to me once. I just shut off the key, pulled it out, licked it (dunno why), wiped it off and put it back in, and it fired right up.
second, my car flooded itself somehow one time. I just let it sit and drove my moms car to work. When I came home I tried it again, I had to turn it over and hold it for a few seconds, but it finally started.
third, make sure it's in gear and the clutch (if a 5 speed) is pushed in. - edit, n/m doesn't sound like this..
Make sure the battery terminals are clean and are in good connecting order. . - edit n/m doesn't sound like this either.
Check all fuses, under the steering wheel and under the hood.
Try an jump start - edit, n/m you tried this.
try a kick start (again if 5 speed).
and last, what have you done since the last time it started?
Old Aug 3, 2003
BLCKOUT's Avatar
[/B]
does licking cause the NAWS system to increase the boost in the injectors?
i bet if you bumped up the injector pulse a milasecond, ya would run 10's
Old Aug 3, 2003
BLCKOUT's Avatar
sorry, im in one of those moods.....dealing with stupid people here at Police Dpt.
Old Aug 3, 2003
pheaton's Avatar
Honestly I dunno why . I think somewhere in my messed up head I thought maybe there wasn't a good connection so the key needed to be cleaned. heh.
Old Aug 3, 2003
skipbarber's Avatar
dude...the gross part is that youve probably used that key to like scratch your ***, and youve probably dropped your keys on multiple surfaces before..and it has touched all the stuff in your pocket...which may or may not be a good thing...
CarStuff
Dec 6, 2020 12:52 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
