Installing new seats, need help...............
Old Jul 24, 2003
importz2k1's Avatar
I took my stock seats off today, and there is a long cylinder attached to the seat belt buckle along with wires (SRS ?)
Now for the question................my new seats wont be here til monday but, will I be able to attach this part to the racing seats so I can use my seat belt, or will I have to buy a 4point harness?
Old Jul 24, 2003
Yukonart's Avatar
Yukonart will become famous soon enough
You will somehow have to connect the seatbelt latch to the new seat's base plate.
Old Jul 24, 2003
CarbonFly's Avatar
I don't have SRS, but my buckle has a long black rod coming off of the buckle. I was able to use my stock buckle on my aftermarket seats. But eventually i got harnesses because i wanted to.
You WILL be able to use your stock buckle.
What seats did you get?
Old Jul 25, 2003
importz2k1's Avatar
The grey and black ones.............
Old Jul 25, 2003
2fly2k2's Avatar
2fly2k2 is an unknown quantity at this point
You cant use your your seatbelts. The rod that you see on the left hand side does unscrew and does come off the seat but if you look all of the wire's that go to the seat belt they are all pulled threw a small opening. Unless you cut those wires witch I am told by Honda will cause all kind of **** to happen you cant get the seat belt piece off. Also if you use the factory seat belts the seat belt part will rubb like crazy on the fabric of your new seat causing them to tear. Do it right the first time ditch those ugly factory seatbelts and put in the harnesses like the aftermarket seat companys intended.
Old Jul 25, 2003
Deejai35's Avatar
Deejai35 is an unknown quantity at this point
^^Thats not true... I have Racing seats and I use my stock seat belts. There should be a spot on your mounting bracket where you can bolt your stock seat belt onto. Its that simple... just unbolt your seat belt latch and bolt it onto the new seat bracket. Then connect the wires back...
Old Jul 25, 2003
2fly2k2's Avatar
My mounting brakets arnt like that but hey I cant say that there isnt a bunch of them out there. Any way I didnt use them and mine would rub thats just me
Old Jul 25, 2003
Maverick's Avatar
Maverick is an unknown quantity at this point
It's true, you can use the stock seatbelts...it just looks kind of ridiculous and it will wear the fabric on your racing seats...You referred to SRS..this light will only come on if you change out your steering wheel..(I get to look at that light daily,thanks to MOMO haha)...but yeah, try to get some racing harnesses if you can..they look and feel better, and according to DOT, are safer.Good luck
Old Jul 25, 2003
CarbonFly's Avatar
You are WRONG........I have racing seats and I know. It WILL work.
Old Jul 25, 2003
2fly2k2's Avatar
AGAIN FOR THE LAST TIME MINE ARNT THAT WAY I DIDNT THINK ANY ONE ELSES WAS DIF. AGAIN THEY WORK ON YOURS THEY DONT WORK ON MINE
Old Jul 25, 2003
Validus's Avatar
Validus is an unknown quantity at this point
bah racing harnesses make you look stupid imo.. Really stupid. I would say most racing seats do too, but those gray and black ones look clean, not obnoxious.
Old Jul 25, 2003
RedDragon333's Avatar
you can use the stock seat belts if you get the brackets designed for the 7thgen civic.
Old Jul 26, 2003
importz2k1's Avatar
That's what I did, I ordered the brackets, and sliding brackets specifically for the 7thgen.
I'll try the best I can, if it doesn't work, I'll get the harness.
Thanks everyone for your input on this, I appreciate it!!!!
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
ballmich
Jul 9, 2015 11:59 AM
fvckbg
Jul 7, 2015 07:08 PM
