how do i remove that plastic around the shift?
Old Jul 23, 2003
2k1lxcoupe's Avatar
blingbling member
2k1lxcoupe is an unknown quantity at this point
i saw it somewhere here a DIY on removing that plasting round thing that goes around the shift stick......i saw it here before but i cound find it!? i think flyrice did it
Old Jul 23, 2003
Yukonart's Avatar
Yukonart will become famous soon enough
Lift up on sectiong of panelling around e-brake. It's held together with only clips. Don 't be afraid to pop them.
You'll see two screws where that panel and the section around the shifter meet. Removed them. ALSO, remove two screws at the base of the center console in the rear. And remove the clips in the same corresponding place up front. (Push in center of clip with something narrow, then pull entire clip out.)
Remove the shift **** by popping the boot off (If I remember correctly), then unscrew the ****.
Now you can lift the entire center console off the floor. Once done, you can flip it over and see the (I think six) screws that hold the shifter section of the center console to the base of the console.
Also, you'll see the tabs that hold the silver trim ring in place around the shift boot. I think I just used my fingers to gently move the tabs out to pop the ring off.
Hope this helps.
Old Jul 23, 2003
Alex1's Avatar
post pics when u get them off, i wanna see how it looks without it. cuz if i could buy the replacement parts without the silver trim i would. i wanted everything to be all black.
Old Jul 23, 2003
alloriginal's Avatar
putang inamo!!!
alloriginal is an unknown quantity at this point
Mannn Yukonart... your car is CLEAN! Something about your car that I like. Those RH go good with your SSM Vic.
OPGForce
Exterior DIY
125
May 20, 2019 04:11 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
mohawkboom
67
Aug 25, 2015 12:28 AM
old97civic
Jul 9, 2015 12:19 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
