throttle linkage DIY'ers, quick question...
Old Jul 17, 2003
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
ok, i finally went in to do the throttle linkage DIY mod. but i just was about to start when i realized there is 2 linkages that go to the TB. one goes to the bronze/gold colored wheel, and the other goes to a black colored rotator with a stopper... heres a pic i just took.
the green arrow points to the one to the gold wheel and the red arrow points to the black wheel.
i would assume that its the gold wheel cable that needs the adjusting, since that what usually controls the butterfly valve. but i'm just double checking.
... ok so i do is loosen the nut on the left of the bracket, then tighten the one on the right, correct? the cable is connected to the black boot-like assembly with the threads, right? so if you just thread the bolts up it'll move the assmbly away from the TB and tighten the cable, right?
Old Jul 17, 2003
cdmx's Avatar
You will figure it out...just push the cable with your finger to see if its getting tighter
Old Jul 17, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
Green arrow!
Old Jul 17, 2003
Skunk2ner's Avatar
ok, but which cable linkage assembly is it? the red or green arrow?
Old Jul 17, 2003
Skunk2ner's Avatar
Originally posted by kjgracing
Green arrow!
thanks bro
Old Nov 29, 2003
Dticalman01's Avatar
Dticalman01 is an unknown quantity at this point
is that the Earlier Cable or the one that's above that one?
Aug 21, 2015 05:27 PM
cukaracha
Aug 10, 2015 08:01 AM
Strycker
Aug 2, 2015 08:40 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
Jul 12, 2015 11:54 AM
