Rev Limiter Removal Or Extention
I need more power. No matter What The cost.
can some one tell me how or explain how they took out or extended
there redline???? does anybody know where to get it done?
how too's would be nice, maby a diy.
email me with respones akrisheo@iwo-jima.usmc.mil or post here.
well when i hoped a big *** median with my lowered car they had to change the shift linkage and when they did my auto lx went from a 1st gear shift at 5 rpm to about 7 rpm so.... maybe there??
You can't just raise the redline. Its there to keep the engine together. You need better valve springs, higher lift, a better cooling system, more air flow, more fuel, etc.... to allow the engine to breathe and survive at higher RPMs.
Turbocharge it, Swap it, or if money is a no problem, just buy a different car, cuz you're not gonna go fast on D17 power.
if you have a k20, buy the Hondata chip, it will bring your 7k redline (si engine) to around 8. Search and I'm sure you'll find it. If you don't want that, Jet makes an ECU upgrade that can raise your limiter as well.
Originally posted by navyedoc
man i go fast know. i have a k20 in it. i just want to know if theres a way to cut the limit!
Just get a Mugen N1 ECU. 9100 Redline and 4700 VTEC shift, but they recommend new Valve Springs. Sets you back $1200 but I bet its worth it.
theres no point to raising your redline if you do no make power past your current redline..i will best any amount of money unless you have some differnt cams, intake manifold or head work in your k20 you will make minimal if not loose horsepower by reving the **** out of it... good luck...you also SHOULD replace your valve springs with stiffer ones so you dont float your valves....ack
and instead of buying the mugen ecu your better off spending the monda on the hondata chip....
ack....
ack....
7thgen Man-gina
thank you i will do that.
what about my girlfriend's
civic d17a2?
civic d17a2?
turbo it.
That's the only real power adder to econo cars like ours. Adding aftermarket stuff like intake/header/exhaust won't be much help and just make your wallet lighter.
O, that reminds me. Replace current parts with lighter material (CARBON FIBER; not just the hood, but the trunk lid, and the fenders as well).
ballmich
Jul 9, 2015 11:59 AM
cgavin1
Jul 7, 2015 07:10 AM
