DIY: Hood Pins Install
Old Jul 5, 2003
CarbonFly's Avatar
Materials:
- Dremel w/assorted attachments
- Drill w/ different size bits
- Tape
- Hood pins
Step 1:
Begin by removing the hood levelers(rubber thingy). Using a dremel, clear out the area of the bottom layer where the hood leveler touches. Use the sanding bit to smooth out the hole.
Step 2:
Put tape on the top of the hood over the area where you will drill through the top layer of the hood.
Step 3:
Put some grease or other marking material on the tip of the pins. Lower the hood so that it goes through the first dremeled hole and touches the CF. This marks your first point for drilling.
Step 4:
Drill with a very small bit from the bottom to the top. Use the grease marking as you drill spot.
Step 5:
Place the scuff plate on the tape and mark your drill points.
Step 6:
Using you template, drill out the center hole. Start off with small bits and move up until the pin can fit through the hole.
Step 7:
Drill a small starter hole for attaching the scuff plate.
Step 8:
Remove the tape and witness your masterful drilling. NO CRACKS AT ALL Sand the center of the hole to make it smooth.
Step 9:
Drill down the scuff plate.
Step 10:
DROOL OVER YOUR BEAUTFUL HOOD!!!
Old Jul 5, 2003
Samari's Avatar
very nice job.
Old Jul 6, 2003
prototype's Avatar
x-factor
flyriceracer ownz grey
Old Jul 6, 2003
CarbonFly's Avatar
True, my DIY's are the best.
Old Jul 6, 2003
024drlx's Avatar
024drlx is an unknown quantity at this point
very nice, good job as well.
Old Jul 6, 2003
Chrisman8995's Avatar
Chrisman8995 is an unknown quantity at this point
did your pins come with the screws, because mine didn't and i get pissed every time i open my hood because i have to hold the damn plates,.............oh yeah what kind of pins do you have?, mine are rusting after 8 months they weren't cheap either....
Old Jul 6, 2003
CarbonFly's Avatar
These are the pins i got......
http://www.motorhead.com/shop/parts/...18&i=a&l=2lnc1
Why didn't you just buy some screws?
Old Jul 8, 2003
i will, i will just havn't got around to it yet
Old Jul 10, 2003
FattyMcJ's Avatar
Addicted to the Twisties!
So just out of curiosity, would I be a total nerd if I put hood pins on my stock hood? I'm just kidding. Nice job on the DIY!
Old Jul 26, 2003
usafstud's Avatar
where on your car frame did you put the hood pins to?
can you show some pics?
i'm trying to get the hood pins on, but on the locations that you seem to put, there are the back of the head light and ac wires
Old Jul 26, 2003
CarbonFly's Avatar
I removed the bump stops from the frame and used those holes for the install of the pins.
Old Jul 27, 2003
usafstud's Avatar
here is a pic of my hood
Name:	my car 019.jpg
Old Jul 27, 2003
usafstud's Avatar
here is a pic under the hood
the installer said that i shouldn't have the hood pins on the corner leveler
instead he is going to put a extender by the silver sticker that he is going to
revet on
how is ur set up working, how do u keep ur hood leveled?
do u use the rubber bumps on the middle of the chassis?
please post a pic how ur set up under the hood
Name:	my car 016.jpg
Old Aug 5, 2003
Derek-CEO's Avatar
Derek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz Erthang
added to diy
Old Sep 11, 2003
yellowcoppy95's Avatar
yellowcoppy95 is an unknown quantity at this point
is there any way that anybody knows how to reinstall the hood lock (the little rectangle thingy on the under side of the hood) off of the factory hood and onto the cf hood?
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
fvckbg
Jul 7, 2015 07:08 PM
cgavin1
Jul 7, 2015 07:10 AM
robbie374
Jul 7, 2015 02:56 AM
