*Updated* MaxRev, SFpower, Turbo Discounters Turbo Kit Info
Old Jul 3, 2003
derty's Avatar
derty is an unknown quantity at this point
Max-Rev Motorsports D17 turbo kit
The Kit Consist Of:
Turbo - Garrett T3-T04 VB35HF
Wastegate - external Tial 35mm Wastegate
Manifold - Max-Rev Stainless Turbo Manifold (CNC cut flange, 1/4 thick wall stinless tubing, TIG welded construction)
Downpipe - Max-Rev 2.5 inch Stainless Downpipe
Intercooler - Max-Rev Large Front Mount Intercooler (high efficiency extruded tube w/core dimension of 20x8.5x3")
IC Piping - Mandrel Bent Stainless Piping Kit
Blow Off Valve - Max-Rev Billet BlowOff Valve and mount
Lines - Max-Rev Stainless Oil Line Kit
Additional - Heavy-Duty Silicon Couplings and Hose Clamps, High Quality Hardware, Connectors, Hose, and T-Fittings
Plus a Lifetime Warranty on manifold and downpipe against manufacturing and materials defects.
$2499.99 and also FREE shipping in the continental US, If members would like to get in on the group buy and want additional options like fuel upgrades or polishing, contact me for additional price.
Dyno: Na
SFPower D17a Turbo Kit
The Kit Consist Of:
Ok, Here is some updated information about the Stafford Fabrications turbo kit.
With the stock exhaust, stock plugs, and 5.5 psi of boost, a 2002 LX made
166 whp and 165 ft/lbs of torque
With that boost level, it ran a (corrected) 1/4 mile time of 14.9 @ 92.7
With a 2 1/2" exhaust and some Denso iridium plugs, i ran a 14.5 @ 97.7 mph at 5.0 psi
Now i am testing some of the new upgrades and i am running 9 psi on pump gas without any problems.
The current available upgrades are:
Air-Water intercooler
Bigger turbo (AR.60 intake)
3" downpipe
The Base Kit comes with:
Air-air intercooler
Garrett T3 turbo (ar.42 int, ar.48 exh)
Intercooler piping (powdercoated, you select color)
2 1/2" downpipe
4-1 tubular collector style manifold
Turbo XS BOV
Map sensor isolation valve
oil lines
oil drain fitting
PFM (fuel system)
Hose clamps and couplers
basic kit $2900 as of now
air to water kit $3400
upgraded turbo $100 extra
Water injection, as low as $50
The phone number to the shop is (661) 816-5444
And you will speak to Mike Stafford
Turbo Discounters D17a Turbo Kit
Superior Kit Consist Of:
1 Garett Turbo/Internal Wastegate
High Nickel Composite Cast Exhaust Manifold
Down Pipe
Fuel Pressure Regulator
Map Unit (Black Box)
Oil Return Line and Fitting
Air Filter w/ piping
Extreme Kit Consist Of:
Down Pipe
Injection Control Unit w/ Turbo Timer
Injector Interface Block w/ Injectors
Blow Off Valve
High Flow Intercooler w/ mounting hardware, pressure tubes, rubber hose connections and clamps.
3 people = 5%:
Extreme: $2,964
Superior: $1,995
6 people = 10%:
Extreme: $2,808
Superior: $1,890
10 people = 15%:
Extreme: $2,652
Superior: $1,785
Dyno: 165.5 HP and 175.2 TQ at 7psi on n318z car
Btw if the info isn't up to date please PM me and I will update ASAP. I just collected the info from the group Buy section and put everything together in one spot so we wouldn't have to read through millions of threads to come across the kit's information.
Old Jul 3, 2003
viciousvolpe's Avatar
viciousvolpe is an unknown quantity at this point
throw some prices in there to and the proven dyno number would be cool too
goodjob on the post too
Old Jul 3, 2003
iamboo's Avatar
Retired - SoCal FI Mod
good post... if you need to update number and etc, please update them in the first post.. thanks...
Old Jul 3, 2003
MikeAtMaxRev's Avatar
MikeAtMaxRev is an unknown quantity at this point
Thank you.
Old Jul 3, 2003
derty's Avatar
could a mod maybe make this thread sticky?
Old Jul 3, 2003
slystad810's Avatar
Doesn't n318z have the Turbo Discounters kit?
Old Jul 3, 2003
sandgrencivic's Avatar
sandgrencivic is an unknown quantity at this point
I have a question, the dyno numbers that are posted, is that total horsepower including what it is now?? Or is that 160hp added to 127hp? Let me know.
Old Jul 3, 2003
Mikee's Avatar
Mikee is an unknown quantity at this point
same question here? cuz if its only 160 hp then its not worth it imo but if its plus 160 dope ****
Old Jul 3, 2003
derty's Avatar
those are the numbers they are pushing now. and we dont push 127hp stock anyways. a stock ex pushes like 110-115. and yes 165hp and 175 tq is worth it, and they are at low boost 6psi-7psi. crank it up to around 8.5-9psi it will be in the 200.
Old Jul 3, 2003
MadWheel's Avatar
Premium Boosted Member
yeah what he said lol
Old Jul 4, 2003
derty's Avatar
ok ok 190ish close to 200 k
Old Jul 4, 2003
SaiyanMatador's Avatar
SaiyanMatador is an unknown quantity at this point
what the shiet are u talking about, with how light our cars are, 165 hp is great. doode completely stock the car runs a mid 15. a 17 second car running mid 15 is pretty damn good, and its not 165 "rated" to the flywheel, thats to the wheels, "rated" to the flywheel will add around ten or more hp, so with respects to that ur looking at around 175 or more horsies.
the car would be as fast as a r sux x type slow <----(rsx type s)stock.
be thankful damnit, those kits are great for the numbers their putting out, and for the price, congrats ur boostin gods
Old Jul 4, 2003
by the way, nice job on the info
eric
Old Jul 4, 2003
Mikee's Avatar
ok thats all i needed to know. thanks
Old Jul 4, 2003
SiN 808's Avatar
SiN 808 is an unknown quantity at this point
Import Tuner dynoed our cars 110hp to the wheels..........so 160hp to the wheels with either kit is very impressive....especially at low boost..........6-7 psi. Just think if we do internals and run it at a higher boost........we will be in the 200hp range or higher to the wheels.....alot of potential.....
if you wanna talk about the weight of our cars..........2dr coupe....3600lbs.........4dr sedan.....3500lbs..........SI.....3800lbs....RSX.. .........4000lbs..........I couldn't believe the 4dr was lighter than our coupes..........funny
Old Jul 4, 2003
Master J's Avatar
Master J is an unknown quantity at this point
whoa where the hell did u get those numbers from...i believe a coupe (ex) is around 2610 the sedan 2694..the si 2744 and the rsx is 2700s (heavier than si by a lil bit)
for those of u wit turbo's im wondering how ur MPG is...i heard someone wuz still getting 37s highway..wonder if thats true
Old Jul 4, 2003
dood, my car, with no trunk weight, interior, on stock tires, no passenger or rear seat, no center console, and all papers and crap, etc removed, 2215, with out me in the car, hehe, with me in 2525
hehe my cars light
Old Jul 4, 2003
iamboo's Avatar
hehe my cars light
you weight 310?? you're a big guy..
Old Jul 5, 2003
SiN 808's Avatar
SORRY! LET ME BE MORE SPECIFIC....MY COUPE......3550LBS.........MY SISTERS SEDAN........3485LBS.........AND MY DADS SI.........3650 LBS.........MY FRIENDS RSX......3790LBS.......TAKE A LOOK ON YOUR DRIVERS SIDE DOOR.....THERE SHOULD BE SOME SPECS ON YOUR CAR INCLUDING WEIGHT.......THATS WHERE I GOT MINE.........I COULD BE WRONG BUT TAKE A LOOK ANYWAY..........
Old Jul 5, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
my CRX was 1600 lbs when i was done with it. And thats with me in the car.
220 whp + 1600 lbs = fast as hell.
Old Jul 5, 2003
MadWheel's Avatar
Sin 808 you are going by wrong numbers, sorry man you wrong! You are looking at gross weights. That number represents the weight of the car PLUS the maximum occupant weight (max wieght of passengers and cargo) My EX - fully loaded with all stock equipment weighs just under 2600lbs. It is a coupe. I beleive sedans are in the vacinity of 2700lbs. A Mitsubishi Eclipse GSX (turbo with AWD) only weighs 3300. That's still a lot but god an RSX weighs no where near what you stated. Not flaming, I'm just trying to clarify this issue.
Old Jul 5, 2003
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
(gvwr)gross vehicle weight rating.doesnt that mean total weight of the vehicle alone?
how did you weigh your car?
not being an *ss, i just want to get my ?s answered.
Sin 808, those numbers are pretty high...i think i saw like 2400-2700 lbs. range somewhere.i use to have the info. but i dont know where i put them.
Old Jul 6, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Gross Vehicle weight rating is the amount of weight with all passengers, fluids, and cargo your chassis was made to handle at a maximum. Curb weight is the the weight of the car by itself, no passengers or drive, and a full tank of gas.
Old Jul 6, 2003
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
Your an idiot. Why the hell would you think that our cars would gain 160 HP? Do you know anything about Forced Induction or that matter cars?! 60 HP is a big gain for our cars and many others! Due some research before your make yourself look like a complete and total ***.
Old Jul 6, 2003
NashVegasEX's Avatar
NashVegasEX is an unknown quantity at this point
From www.hondacars.com
Curb Weight (lbs., MT/AT)
DX - 2402 / 2452
HX - 2436 / 2507
LX - 2474 / 2507
EX - 2554 / 2594
Old Jul 7, 2003
SiN 808's Avatar
k guyz I went down to Honda with my gf the other day and asked them for the weight of our cars and this is what I got......
2554/2594 EX COUPE
2601/2652 EX SEDAN
2744/2752 CIVIC SI
2694/2771 ACURA RSX
Damn I got some F@#ked up numberz.............sorry yall.....!!!!!!
Old Jul 7, 2003
nopher2's Avatar
nopher2 is an unknown quantity at this point
hey zinky, he doesn't know man. as everyone has said before, we were all noobs once, so don't dawg him man, that's unnecessary
Old Jul 8, 2003
Deejai35's Avatar
Deejai35 is an unknown quantity at this point
I apologize for cutting into the current conversation, but this fits the topic. I didn't want to start a completely new thread about this, but I did want to give everyone a heads up.
There is a new turbo kit for our cars being built now. The design phase is over, and the parts are currently being constructed so that they can be put on the car and test it. As the kit has not been tested or completed, I can only provide limited information at this time.
Who: Xtreme Power & Performance (XPP Racing)
What: 2001+ Civic Turbo kit (EX at first...)
When: Full production by the end of summer
All I can tell you at this point is that it will be competitive with the other turbo kits, but will definately be a different setup. And it will be upgradable to other stages.
Old Jul 8, 2003
ncwcivic's Avatar
ncwcivic is an unknown quantity at this point
Man i hope they turn out some good numbers, I am looking at the SF kit but am willing to wait for better pricing, even thought there are some good prices out
Old Jul 8, 2003
opto_isolator's Avatar
See - that's a good thing. Its not that I don't like the current offerings of kits out there. But I like competition. I like options. I like the fact that I have choices.....
Can't wait!
