19's What springs?
19's What springs?
I just bought a set of 19" Axis Spyders and They rub!!! I have 215/35/19 Pirelli tires on them. I have koni struts, Eibach sportline springs and SPC camber kits on the front and back. I have already rolled the rear fenders. Now they only rub when I hit a bump turning and the front will rub a bit when I turn at higher speeds. I want a new spring that has less than 1.75 drop. I want maybe a 1" drop would be fine, needs to be kinda stiff but still a good ride. I DO NOT WANT COILOVERS! Any Ideas? If anyone has 19's I'd appreciate any help.
um set the reat to a little more negative then usual. You will wear your tires down more but it won't rub as much. The Eibach prokit is only a 1" drop and after settling a little more. That should do ya. Everything else might be too low for those tires. Even then you still might rub going over bumps or speed humps. Are 19's really worth it??
Search and Learn
umm why dont you just get full coilovers? i understand you dont want coilovers but why not? tein ss. b&g rides great.
prokit would work well as well if you really want springs.(1')
I have 19s on my car with Ground Control coilovers. My car is like 1.5 inches and dropped and it doesnt rub. I dont know y u rub. My friend Vu had 2 inch drop on 19s when he had his 2k1 no rub. What offset are ur rims cus I never ever rub no matter if I have 4 or 5 people in my car.
Hmmm I dont know. Post a pic of ur car. I dont think its cus u have 19 x 8 cus theres a couple guys here in Houston that have 19x8 I just dont know what offset but they dont rub. Maybe ur camber is adjusted to much.
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
