what do i need with coilovers?
Old Jul 1, 2003
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
i was thinking about getting the skunk2 coilovers. what else do you reccommend for optimum performance?
i was looking at the skunk2 coilovers but they don't have a shock. do i need to purchase shocks for them?
(sorry if this is a dumb question).
Old Jul 1, 2003
DevilsSi1481's Avatar
DevilsSi1481 is an unknown quantity at this point
yes u would definately want shocks, since lowering a car will make the stock shocks go out on u right away. Koni yellows r the best ones u can get but Tokico Illuminas and KYB AGX's r also a nice set. also u might want a camber kit in order to align your wheels right when u lower your car, i think Ingalls would be a good one for front and back.
Old Jul 1, 2003
djmota's Avatar
You will need shocks Koni yellows are the only ones out right now. They are expensive and you need to gut your front struts to install them(fronts are only inserts. If you have the cash get a full coilover setup from B&G or TIEN.
Old Jul 1, 2003
Skunk2ner's Avatar
are true-coilovers superior in performance than sleeved coilovers with shocks?
would i get better performance out of the B&G or TIEN than the skunk2's with the koni's or tokico (when they come out)?
Old Jul 1, 2003
robbclark1's Avatar
Retired suspension supermod.
yes they are better. They are one piece and designed to go together. matching sleeved coilovers to shocks will vary. I mean skunk2s plus tokicos will be different than skunk2s with konis or kybs.
Old Jul 1, 2003
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
Ground Control's + Koni Yellows = very nice
Old Jul 1, 2003
djmota's Avatar
Agreed. Good quality sleeved coilovers with good shocks are very nice.
I luv my setup. But True coilovers where designed to work together and will offer better performance. Sleeved is the econo way to have adjustability. But since Koni yellows are the only aftermarket shock available at about $550 a set Its not as econo as it was intended to be.
Old Jul 2, 2003
civicvtec1ps's Avatar
Search and Learn
true coilover is the way to go.
Old Jul 2, 2003
Skunk2ner's Avatar
ok... so if the koni's are like $550 and the skunk2 coilovers are like $350 (give or take) thats like $900... and true-coilovers are not much more than that are they?
so which offers the stiffer, more race oriented true-coilover, B&G or TIEN?
Old Jul 2, 2003
Teins r great!
Old Jul 2, 2003
Search and Learn
tein basic is around 900-950
tein ss 1000+
b&g 950+
Old Jul 3, 2003
Skunk2ner's Avatar
tein ss 1000+
b&g 950+
well if i'm coughing up $900 anyway, i won't mind to put up another $100+ to get the tien ss'.
so between the tien ss and the b&g, which is the most track worthy?
Old Jul 3, 2003
Search and Learn
tein ss. you can adjust damper setting, the way you want...
Old Jul 4, 2003
rainn's Avatar
rainn is an unknown quantity at this point
does anyone have koni yellows installed? i read that they make alot of noise and movement. i got skunk2 coilovers and was planning on getting koni's not sure what to do now?
Old Jul 4, 2003
MIT's Avatar
MIT
MIT is an unknown quantity at this point
i got tein basic for 840. dont ever pay tha 900 for the basic, cuz add 100+ more u can get SS.
GolNat
Nov 27, 2018 03:32 PM
wingsfan19
Oct 1, 2015 03:45 AM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
EM_WON
Jul 22, 2015 06:49 PM
