19's What springs?
Old Jul 2, 2003
Hondasport01's Avatar
Hondasport01 is an unknown quantity at this point
19's What springs?
I just bought a set of 19" Axis Spyders and They rub!!! I have 215/35/19 Pirelli tires on them. I have koni struts, Eibach sportline springs and SPC camber kits on the front and back. I have already rolled the rear fenders. Now they only rub when I hit a bump turning and the front will rub a bit when I turn at higher speeds. I want a new spring that has less than 1.75 drop. I want maybe a 1" drop would be fine, needs to be kinda stiff but still a good ride. I DO NOT WANT COILOVERS! Any Ideas? If anyone has 19's I'd appreciate any help.
Old Jul 2, 2003
robbclark1's Avatar
Retired suspension supermod.
um set the reat to a little more negative then usual. You will wear your tires down more but it won't rub as much. The Eibach prokit is only a 1" drop and after settling a little more. That should do ya. Everything else might be too low for those tires. Even then you still might rub going over bumps or speed humps. Are 19's really worth it??
Old Jul 2, 2003
Yea the 19's are badass!!! Sould I be using my bumpstops with the koni's? That wouldn't let the strut compress as much and prolly keep it from rubbin'.
Old Jul 2, 2003
robbclark1's Avatar
hmm i don't know about that one. BTW i think ken found the other **** to adjust the konis.
Old Jul 2, 2003
civicvtec1ps's Avatar
Search and Learn
my friend rolling 19s 215/35/19
he has gc coilovers with koni yellow
dropped at least 2...
no rubbing he said...
Old Jul 2, 2003
Search and Learn
umm why dont you just get full coilovers? i understand you dont want coilovers but why not? tein ss. b&g rides great.
prokit would work well as well if you really want springs.(1')
Old Jul 2, 2003
TOOLOWCIVIC's Avatar
I have 19s on my car with Ground Control coilovers. My car is like 1.5 inches and dropped and it doesnt rub. I dont know y u rub. My friend Vu had 2 inch drop on 19s when he had his 2k1 no rub. What offset are ur rims cus I never ever rub no matter if I have 4 or 5 people in my car.
Old Jul 2, 2003
maybe cause they are 19x8 not 19x7.5??? I was told they are +40mm offset
Old Jul 2, 2003
What if I took off my sportline Springs and put in the pro kit, and put the bump stops back in will that fix my problem?
Old Jul 3, 2003
Hmmm I dont know. Post a pic of ur car. I dont think its cus u have 19 x 8 cus theres a couple guys here in Houston that have 19x8 I just dont know what offset but they dont rub. Maybe ur camber is adjusted to much.
Old Jul 3, 2003
DarrenA's Avatar
DarrenA is an unknown quantity at this point
TOOLOWCIVIC, I must say your car is straight up awesome. I just love the way it looks. I guess thats all.
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
