compression ratios?
Old Jun 28, 2003
aznstylez254's Avatar
Jspek Inspired
aznstylez254 is an unknown quantity at this point
compression ratios?
can someone explain this to me... whats the point of having high or low compression?
im sorry if this is something im already supposed to know.
Old Jun 28, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
High compression makes more power in naturally aspirated engines because you can pack a lot of air in, then compress it into a very small area... the pressure it creates gives you the power.... when a car is 11:1 compression, that means there is 11 times the volume at the bottom of the stroke as there is at the top... The spark and ensuing explosion that occurs when the piston nears the top forces it back down, turning the crank over.
Low compression is usually used on cars with forced induction (Turbo or supercharged) because the air is already pressurized coming in. Using high compression and pressurized air creates a tremendous amount of heat that usually causes lots of problems. You will find that both high compression N/A engines and Turbo/SC engines have very effective cooling systems to keep the engine cool... because both can create a lot of heat.
Theres probably a more in depth explaination somewhere online, but I don't feel like looking for it.
Old Jun 28, 2003
Jspek Inspired
well thx for giving me the basics though
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
runawaykinms
15
Mar 22, 2019 10:32 AM
Sep 27, 2015 11:33 AM
NROD315
Sep 12, 2015 02:46 PM
darwin-t
Aug 15, 2015 10:51 AM
