Finally Got A Ticket For My Yellow HEADLIGHTS!!!, Not Happy
Is There Anyway To Come Out Of This Without Paying Anything Im Not Sure Wat The Fine Is Exactly But Better To Not Pay Then To Pay Something. By The Way I Live In Nj..
Still kinda in the dark BUT...
The only color of lights that are allowed to shine forward are white & orange (amber). You can have blue and yellow bulbs so long as the color shows white.
I found this in the New Jersey Permanent Statutes database
Looks to me that the yellow lights can only be installed as side markers....read up and see what you think
reps are good
39:3-50. Color of lights, permits; cancellation or revocation of permits
All lamps and reflectors, which display a light visible from directly in front of a vehicle as authorized by this subtitle, shall exhibit lights substantially white, yellow or amber in color.
(a) The color of light emitted or reflected by exterior lamps or reflectors on a vehicle shall be as follows, except as otherwise provided in paragraph (b), (c) and (d) of this section:
White when the lamp is a headlamp, or spot lamp, or illuminates a license plate or a destination sign; or is located on the outside limit of a side car or other attachment on a motor cycle;
Substantially white or amber when the lamp is a side-cowl or fender lamp, running-board or other courtesy lamp, front parking lamp, back-up lamp, auxiliary driving lamp; or a turn signal on or facing the front;
Substantially red or amber when the lamp is a turn signal or a stop lamp on or facing the rear;
Red when any other lamp or any reflector is on the rear or on either side at or near the rear, except as otherwise provided in paragraph (f) of section 39:3-61 for a combination marker lamp;
Amber when any other lamp or reflector is on the front or on either side other than at or near the rear.
(b) Lamps and reflectors on projecting loads shall emit or reflect light with color as provided in section 10 of this act.
(c) No person shall drive or move any vehicle or equipment upon any street or highway equipped with any device or lamp thereon capable of or displaying a light of any other color than permitted by this section, except: an authorized emergency vehicle, an authorized school bus, or a vehicle authorized by a permit issued by the director.
(d) A permit authorizing a vehicle to be equipped with a lamp capable of or displaying a flashing light, except as provided in 39:3-54 or a light of a color other than permitted by this section, visible from directly in front of said vehicle, may be issued by the director when necessary, in his discretion, for the reasonable and safe movement of traffic. The permit shall specify the type and color of such lamp and the conditions under which a person may drive or move the vehicle with said lamp displaying a light. The permit shall be valid only when the specifications and conditions contained therein are complied with.
The director may cancel or revoke a permit issued under authority of this section whenever the conditions for its issuance no longer exist or on any other reasonable grounds.
Amended by L.1951, c. 24, p. 121, s. 1; L.1964, c. 136, s. 3.
39:3-51. Auxiliary driving lamps
Any motor vehicle may be equipped with not to exceed two auxiliary driving lamps mounted on the front at a height not less than twelve inches nor more than forty-two inches above the level surface upon which the vehicle stands, and every such auxiliary driving lamp or lamps shall be so aimed and used that no part of the high-intensity portion of the beam will be directed to the left of the prolongation of the extreme left side of the vehicle nor more than one hundred feet ahead of the vehicle.
39:3-52. Additional lighting equipment
Any motor vehicle may be equipped with not more than two side cowl or fender lamps which shall emit a white or yellow light without glare. Any motor vehicle may be equipped with not more than one running board courtesy lamp on each side thereof which shall emit a white or yellow light without glare. Any motor vehicle may be equipped with a back-up lamp either separately or in combination with another lamp; except that no such back-up lamp shall be continuously lighted when the motor vehicle is in forward motion.
reps are good
Crack kills... But then again... So do I...
Hopefully you can just change out the bulbs. Show the judge that you already repaired the problem. on a good day, you should get off with just court costs.
Originally Posted by SleakCivic02
Read Dumbass
^^My post above still stands...Look at the NJ law code for lights on vehicles
THE LONE STAR STATE
The name of the form is
Read Dumbass
Read Dumbass
Touge
Ottawa
Aug 20, 2015 11:35 PM
Touge
martinsmartin
Aug 15, 2015 07:34 PM
cyc
Jul 22, 2015 01:14 PM
sch2cm
Jul 21, 2015 09:58 PM
