my car is dead! (well.. half dead)
Old Apr 20, 2005
skiboard's Avatar
Today, I drove for a while and when I was parked to see the map, the car was shaking, so I was what the hell and looked at the RPM guage, and it was dropping to zero and back up, drpiing to zero and back up.
I thought it was nothing but random thing that happens. so I put my car in reverse, but while reversing, car shook and died. never happened before, so I turn my car on again, put it in Drive, and drove. but it wouldnt go over 3000rpm and doesnt want to go from first gear into second or third gear.
damn it.
also, sometimes when I am on Park, RPM bounces around sounding/shaking like it's gonna die soon
What could be wrong?
engine oil, tranny fluid seems alrite. checked to see intake filter but looks clean.
I had resgenator taken out for 2 days from stock intake and put it back on but still having problem
Old Apr 20, 2005
SuperFishy's Avatar
Nugget Garage Wannabe
SuperFishy is on a distinguished road
not sure about civics, but maybe one of your vacum hoses poped off, check your spark plugs too maybe? althought they wouldn't fail just like that.
Old Apr 20, 2005
Reset the ecu, make sure there's no engine light. Otherwise it may be a sensor or you could try raising the idle rpm.
Old Apr 20, 2005
_Viper_'s Avatar
ITS your MAF sensor dude ......or MAP whatever they call it
REP please
Old Apr 20, 2005
skiboard's Avatar
yeah.. but what about the map sensor? has it gone bad? or it needs cleaning?
I resetted ECU but after test driving, it came on again
also where would I locate vacum hose?
Old Apr 20, 2005
They are all around, mainly around the throttle body. Just make sure they're all pushed in and clamped. Get some TB cleaner and wipe inside the TB (you can open the valve with the lever to clean inside. Might just be dirty. It could be your tps or map sensor, in which case its new throttle body time. Get the code checked for the engine light first.
Old Apr 20, 2005
skiboard's Avatar
code was checked and it said O2 sensor problems
cant remember but I think it was
P0130 O2 Sensor Circuit Malfunction
or P0135 O2 Sensor Circuit heater Malfunction
Old Apr 20, 2005
Then replace the o2 sensors.
Old Apr 20, 2005
skiboard's Avatar
isnt it like couple hundred dollors for O2 sensors? ahh.. I guess trip to Honda dealer
one thing I am thinkin is that my dad used my car last nite into town and got 94Octane gas, which I dont normally get. Also it happened after I took the resegenator off for two days and rained today..... this is giving me too much stress
Old Apr 20, 2005
Don't worry. Yea getting that gas was a bad idea, but just run it out and go back to regular. o2 sensors aren't that expensive. I think you can even get some from an auto parts store. I doubt its over $50.
Old Apr 20, 2005
skiboard's Avatar
gearbox, by re adjesting idle RPM, do you mean doing it by adjusting the tottle cable?
Old Apr 20, 2005
Tofast4me's Avatar
Tofast4me is a glorious beacon of lightTofast4me is a glorious beacon of lightTofast4me is a glorious beacon of lightTofast4me is a glorious beacon of lightTofast4me is a glorious beacon of light
02 sensors are a few hundred from Honda. They are cheaper if you buy them from the states but good luck getting them to ship to Canada. I thought the same that they couldn't be that much but the guy at Honda told me different
Old Apr 20, 2005
skiboard's Avatar
but I doubt it's idle rpm thing tho cause while I was in highway doing 110, suddenly felt shake and rpm dropped. I tried punching the gas, but nothing happeded. or is it just my ECU putting car into safe mode?
Old Apr 20, 2005
ya safe mode when the engine light comes on. By idle I mean adjusting the set screw to raise rpms by opening the throttle plate more. It's prolly not that tho cause everything should be computer controled. If you need an o2 sensor I could see how much they are here and ship it to you if it ends up being cheaper.
Old Apr 20, 2005
Tofast4me's Avatar
I think it was like $30 in the states and over $200 in canada. I don't remember if it was that high but I remember it being alot higher then in the states.
Old Apr 21, 2005
skiboard's Avatar
I will check local stores and let you know the price
Majestic Honda sells it for $35 I think
went out to garage and tried everything but still nothing.
there were one more thing. this ghetto alarm setup by me. I connected some wires to RPM wires but never had problems. I just cutted it out but still having same problem..
maybe I should just bring to Honda or a shop
Old Apr 21, 2005
Big Baller L's Avatar
Nugget Garage Since 2004
hmm i dunno what that could be. Ive had a cel for my high flow cat for a while and i noticed so drop in performance but my car never dies or anything. I dont know what that code is but check what everyone else said. Maybe you shorted one of the wires by hooking up ur alarm system. How long was the engine light on?
Off topic: viper ur a rep ***** if ive ever seen one "its ur passenger seat....rep please" LMAO...haha
Old Apr 21, 2005
skiboard's Avatar
it was on from this morning... O2 Sensor can break with water +hot? cause I have vented hood and water dropps on to the header possibly 02 sensor
Old Apr 21, 2005
yea water can ruin it. Why not cover the vents when it rains?
Old Apr 21, 2005
skiboard's Avatar
hmm because I never had that problem before..
thanks for the help that you are giving me Gearbox
seems like this thread is problem that I am having. I should PM him askin what happened next.
http://www.7thgencivic.com/forums/sh...ight=o2+sensor
Old Apr 21, 2005
liljoe's Avatar
liljoe is an unknown quantity at this point
ok, i just read this after i replied to your PM. Check the stuff I told you about (primary O2) but I would also check out your sensor wire that goes into your airbox. (IAF or AIF or something like that?) If you just recently took your resonator off, maybe that wire got pulled out or damaged? Also, maybe try Putting regular gas in there, the higher octane gas could be messing it up. Definitely reset you computer after checking everything out. Pull you negative off your battery for around 10 min and then put it back on, start you car and don,t touch the gas for 5 min.
Old Apr 21, 2005
Pharoh's Avatar
Bobaganoosh!
I got my o2 for around $225 installed last year I think...I would have to look for the invoice.....and that was at Honda.
Old Apr 21, 2005
EŽik's Avatar
Wonn Young, dude thats SUCKS!!! Try what everyone said, if nogo, than goto Honda. They'll definately tell you whats wrong... but for a hefty price.
Old Apr 21, 2005
skiboard's Avatar
Still not working
I feel like Shandon bahaha just kiddin man..
Upd-Ate
It's Moving but something is Fked up. so I went to honda in Bank st. thay are like "OK sir, your car will be looked at on wednesday, 2 weeks later and it's $51 just to check the engine code + $$ for other inspection." said fkit and I went to Ottawa honda, where I usually go and I talked to the guy for while trying to find out whats wrong with it, he suggestes to try find it on my own cause if I bring it to them it's still $51. So I drive around and problem got bigger so went to some random shop (one infront of Bestbuy in Vaniea) and the owner did a testdrive of my car, gave me some ideas and booked an appointment tomorro morning. probly gonna get charged $100 just to find out whats wrong.. I wish I know what's wrong and be able to replace it on my own.. damn it..
Old Apr 21, 2005
I feel your pain...i payed the 50 bucks for my 02 sensor problem. Ive had "similar" problems but never has the car died or not gone over 3000. I dont know what to say man.
Old Apr 22, 2005
liljoe's Avatar
don't go to any honda dealer. you can get the code checked for free at part source. the dealers are a55holes!
can you still drive it? are you coming out tonight? I'll check a few things out for you if you want, or if you are available during the day maybe i can check it then.
does anyone here have a code reader? jim?
Old Apr 22, 2005
Pharoh's Avatar
Bobaganoosh!
I wish I had a code reader..
only time I had a problem with RPM's was when the oil shifted in my pan and the VTEC wouldn't kick in due to lack of oil....sorta like a rev limiter....car lurched like crazy.
Old Apr 22, 2005
EŽik's Avatar
^ That was on the way up Gatineau Park Rd right.
McD
Apr 22, 2015 05:28 PM
