Freddy, the blue controls!
Old Jun 18, 2004
  #31
TeLLy's Avatar
Yes, it's an Acura EL
squeeze - I'm a lil apprehensive about this one, I've almost perfected it - I fuqt my own up and had to redo it tho. But if you're willing to take the chance, by all means you're welcome to drop it off.
Freddy, I use the 5mm for the illumination on the rotary controls (temp, vent select, fan strength) as well as the backlight for the three buttons. Gotta dremel the lips off the bottom of the LEDs themselves, but otherwise they fit just fine. Also I use the 5mm for the backlighting on the power mirror and cruise. The 12000 mcd hyperwhites are only available in 5mm, which is how I was forced to use that size. With a little grinding, they fit, and are STILL brighter than the 3mm's. The 5mm blues are just a bit brighter than the 3's as well.
Old Jun 18, 2004
  #32
Lynk's Avatar
ok, thanx for the info
Old Jun 18, 2004
  #33
squeeze's Avatar
squeeze is an unknown quantity at this point
FreddySi...yo just place the new face (mph) over the OEM one right? But won't the numbers be aligned improperly..
Old Jun 18, 2004
  #34
squeeze's Avatar
Telly, thanks for the info..i'll just hold off for a lil bit...i'm pretty damn lazy too u know...
I still haven't replaced the shifter light yet...
Old Jun 18, 2004
  #35
TeLLy's Avatar
Did you find out what kind of bulb it is?
Old Jun 18, 2004
  #36
Lynk's Avatar
yeah, i just slipped them over. my numbers align properly. They are designed to allign with the original gauges.
Old Jun 18, 2004
  #37
squeeze's Avatar
TeLLy- no not yet..that's how lazy i am..so i should get that done soon
FreddySi - oh..i just thought that becuz the mph is now on the outside and the oem face has the km/h on the outside that it would look wierd...
Old Jun 18, 2004
  #38
Lynk's Avatar
no, it doesn't look weird... well it does if you're not used to seeing mph gauges, he he
but they allign really well, the 50mph alligns with the 80km/h, that's all that's important! he he
here's what they look like during the day
Old Jun 18, 2004
  #39
squeeze's Avatar
Thanks a lot...i'm still waitin for mine...i can't wait...i'm like a lil boy in a candy store.......
estes53
Jul 20, 2015 10:43 PM
