Archive - Canada Forsale/Trade eh? Only post here if you have item for sale in Canada and will only sell to someone in Canada. Please start threads with your Province, like this: ON: or AB:
WTB: Installation services
Old Aug 23, 2004
Amer786's Avatar
Senior Member
Amer786 is an unknown quantity at this point
I have a four channel amp running my in-car speakers right now and I am looking to add a two channel amp to run one MTX sub. I am looking for someone who is willing to do the install for me at a reasonable price. You must have done this before, I dont want somone trying to learn on my car and have the car catch fire or something :-).
I do have a few questions...
1. My current amp kit is only a 8 gage. What would I need to do for the set-up I want, would I have to get a whole new 4 gage amp kit or would 4 gage power wire be sufficient? The other items in the amp kit will just be regular thickness, right (ie ground wire in 4 gage and 8 gage is the same thickness?)
2. Do I need a ground block dist. and a power dist?
3. I have also have a second wiring kit I bought that is 8 gage for the second amp
4. The amp will be mounted in custom board already installed behind the seat.
Anyone who is interested in helping me out, let me know. Also please let me know if I am missing anything in terms iof parts. I will buy everything you need and so there is no time wasted.
It must be a clean job
Old Aug 23, 2004
AlienX's Avatar
AlienX will become famous soon enough
Amer, to make things easier for you. Drop the 8 guage, go 2 guage. You will need a power dis, no ground dis.. all amps must have their own ground to the car. You can have your 4 channel running the 8 guage from the power dis, and 8 guage ground. The MTX depending on its amp rating will be running anywhere from 8 to 4 guage.
WIth the 2 guage setup, you will leave room for more amps to flow incase you ever deside to upgrade amps or add 1 more low ampage amp. Thats is my 2 cents.
On top of that, you should just do it your self. It takes about 1 hour to do the whole install; from RCAs, to removing your old wire and upgrading to 2 guage. If your deck has multiple preouts then you should run seperate RCAs for your sub amp but if it doesn't then you will just run from one of the amps pass though RCA connections saving you even more time on the install.
Old Aug 23, 2004
Amer786's Avatar
Senior Member
But I do not even know where to start on doing it myself, I dont wanna start something and mess things up. All I am running is a single sub so it should not be draining that much bower it is the MTX 8304 I think. I am going to run 4 gages to both amps. I might take your suggestion about going with 2 gage.
Any one willing to do the install....pweeze
Old Aug 23, 2004
AlienX's Avatar
amer,
http://www.7thgencivic.com/forums/sh...d.php?t=153828
if you still need a extra hand I will be willing to help you.
Old Aug 23, 2004
Amer786's Avatar
Senior Member
As in will you come and do it for me ? :-) I just am not comfortable with taking the car apart on my own, and for another thing I am not sure how to remove the headunit, it is a CDA-7998, how would you remove that. Could somoene just take $50 and do it for me, everyone seems to say that it is an easy job requiring at most an hour, so who is willing to make $50/hour, I will even throw in lunch at the local McDonalds !!!!!
Old Aug 23, 2004
AlienX's Avatar
LOL, Amer I will do it for free man. Dont worry about it. Thats why there is 7thgeners around to help each other out. Think of a time and date and we can meet up somewhere and do it.
Old Aug 24, 2004
Amer786's Avatar
Senior Member
Do you have a job, cuz if you dont I am taking Friday off, perhpas that might be good. IF not then how about Sunday? Let me know. I still have to get the parts thoough. Maybe a 2 gage kit. Like I said, I already have a 8 gage kit in the car and another one for the second amp. I got a good price on it so I dont wanna upgrade to 4 gage if i dont have to right now. I also need to get a power block. Tell me, do brands matter? I mean a Stinger brand block can be had for about $20 at futureshop.
Old Aug 24, 2004
AlienX's Avatar
brands dont matter just make sure that if you are going with my 2 guage idea that you have a block that can accept 2 guage and output down to 8 which should be no problem, otherwise its pretty much all looks.
Yes I do work, every evening 6:30pm-12am and Fridays 2pm-11pm. Saturday I work 8:30am-4pm so if something Thursday is the best day and sometime around 3pm-5pm would work for me; thats if you dont have work during that time.
Old Aug 24, 2004
Amer786's Avatar
Senior Member
Wow you work 7 days a week? Well I am at work from 9-5pm but I could probably get away early if I was sure that you were available. Boss is away this week so I could do something this week. If it was Thurs at 4 pm would you have enough time to complete the job and make it to work as well? How much time will you need. Do you know how to remove my HU it is the CDA 7998, I have the manual with me as well.
How about Friday at like 10 am or so... let me know.
Old Aug 25, 2004
AlienX's Avatar
Sunday I have off.. 6pm-12am is mon-fri
I'm off to montreal friday at 5am. Thursday 4pm,np ! 100% I can install it, get it working and everything under an hour. The deck should be no problem to remove, it should just be a slide clip. Better question, my house or yours.. all depends if you have the right tools, which you probebly dont so i'm guessing your coming down to sauga.
Old Aug 25, 2004
Amer786's Avatar
Senior Member
I am still in the process of getting the cabling and and the dist block, so it might take me some time. Futureshop wants like $169 + taxes for a 4 gauge kit. If I order from Sounddomain online I can get a 2 gauge for $72-$90 US. Also I already have a neon connect and wired from the back of the car to the front. If I want to say add more in the future, what will I need, will a dist block with enough outputs the only requirement or would I need something else. The existing neon has burnt out and it is attached via the cig lighter. Maybe we can do the install next Sunday, Aug 29 or the folowing Sunday, depdning on wheni i get the parts, or you can suggest a place locally where i can get it for a better price.
Let me know
Old Aug 25, 2004
SiG's Avatar
SiG
PM sent
Old Aug 25, 2004
AlienX's Avatar
well since you already have everything you can buy the wires by the foot and stuff.. and a fuse can cost you almost nothing... I hear the flea market has kits for cheap...
I will get back to you.. i'm getting ready to go to montreal and i'll be back monday.. if you want me to do it, then we have to do it very soon because i'm leaving to university soon and its out of the city..
Old Aug 25, 2004
Amer786's Avatar
Senior Member
Ok when you are back on monday we can set something up for that week, but i understand if it will be a tight schdule for you. If we cant work something out then it is cool, SiG gave me the number of somone he knows that can hook me up. But I will talk to you when you are back from montreal
Old Aug 26, 2004
AlienX's Avatar
alright. Well talk monday.
jherna85
General 7th Gen
Jul 9, 2015 08:10 AM
jdawgzcivic
Jun 30, 2015 06:35 PM
RIPSAW
Jun 9, 2015 08:33 PM
