CF Tail lights - NO MORE!
Old May 17, 2005
Blue-Wolf's Avatar
Just your Ordinary, Average Guy... IN A HOT CIVIC!! HAHAHA!!
Blue-Wolf is an unknown quantity at this point
Unhappy CF Tail lights - NO MORE!
Well, I broke my CF tail lights. The seal gave and one filled with water in the car wash as I was spraying the car down. I'm putting new ones on tomorrow.
What I was wondering tho, is there a way to open the lens from the light so it can be cleaned and resealed? What I was thinking was heating them up somehow then prying them apart. Anyone have suggestions or anyone maybe done this type of thing before?
Old May 17, 2005
Graphicdude's Avatar
Creative Mind Extraodinare
Graphicdude will become famous soon enoughGraphicdude will become famous soon enough
i would think you could the same thing that guys do to clear their headlights? Check the DIY for the info
Old May 17, 2005
ExZaCc's Avatar
Look what i did..
ExZaCc has a spectacular aura aboutExZaCc has a spectacular aura about
yea you can use a heat gun to open the cover up from the lense.. then clean and reseal..
Old May 17, 2005
Blue-Wolf's Avatar
Sounds good. I'll give it a try. I saw the headlight DIY and wasn't sure if it could be done the same way. thanks for the input.
Old May 20, 2005
kornsined's Avatar
should be done the same. heat with a heat gun/oven, pry apart, dry, then reseal. or if possible, works with headlights, take out a bulb and use a blow dryer to clear up the moisture.
Old May 21, 2005
Blue-Wolf's Avatar
It's not the moisture I'm worried about. It's the dirt that got in there that concerns me now.
no worries. I'm going to play around with it Saturday and see what I can do.
Poopies
Apr 20, 2017 11:36 PM
shaejb15
Apr 12, 2015 11:38 AM
