FS: RSX Engine Swap K20A3
Old Sep 10, 2004
  #31
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
-fitting is not a problem, ive seen it in a CRX and well fitted.
-but...dont forget about the immobilizer thats on the BCM/ECU, if you cant bypass the ignition... the 1600 will go down teh drain.
-you might be able to use the reader on the civic but you need to swap out the BCM/ECU and copy(the programming) the k20's original key. you dont want to tow ur car to dealer and let them charge you thousands of dollars.
Old Sep 11, 2004
  #32
diycx's Avatar
diycx is an unknown quantity at this point
The immobilizer is no problem on 7th gen civics. You just have to take your car to the dealership to get it programmed. Hasport has an article on the swap:
http://www.hasport.com/News/Articles/ESK1.htm
Old Sep 18, 2004
  #33
kornsined's Avatar
how's the sale going??? sold it yet? I would of bought it but money is tight right now. it may be a possibility if it's still around in a month or two. also still waiting to see what pe tuning says what a cost estimate is for this swap.
Old Sep 19, 2004
  #34
Blue-Wolf's Avatar
Just your Ordinary, Average Guy... IN A HOT CIVIC!! HAHAHA!!
Blue-Wolf is an unknown quantity at this point
Will this engine drop in to a 2004 Honda Civic DX-G? Or do I need to do a whole bunch of modifications to make it fit?
Old Sep 19, 2004
  #35
Blue-Wolf's Avatar
Just wanted to know cause I plan to 'rape' the car over the winter. Just trying to find a somewhat reliable 500 dollar winter beater at the moment.
Old Sep 19, 2004
  #36
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
This engine will pretty much drop in, you will need new mounts and a new front subframe.
Old Sep 20, 2004
  #37
Blue-Wolf's Avatar
Hmmm, wonder what a subframe costs. Guess I have to phone the dealer. :-)
Old Sep 23, 2004
  #38
chrisgushue's Avatar
Bring Hockey Back!
chrisgushue is an unknown quantity at this point
ive heard the intake manifold on this wont fit so youll need to get a type s manifold or a sir manifold, i was oging to buy this engine a while back but the cost would of been around 4000 installed with all the parts you need
cloudguy
Apr 28, 2015 05:02 AM
shawe90
Apr 14, 2015 07:10 PM
SugarRay
Bolt-on Engine Performance
19
Jan 8, 2002 02:55 PM
robbclark1
Dec 12, 2001 12:18 PM
supercivic01
South
Nov 30, 2001 11:27 AM
