Polk MM6's
Old Jul 5, 2004
kornsined's Avatar
Polk MM6's
I'm possibly selling these because they do not fit my civic. I paid $260US for these any they haven't even been used. Although the installer shaved down the siding of one of the tweeters. 50/50 will know soon if i want to sell them.
Old Jul 5, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
Don't fit ? are you sure ? Did you get the right size ? I have seen some MM6 on 7th gen civics. I wanted to get them but the polk rep would not get back to me.
Old Jul 5, 2004
kornsined's Avatar
do you know where they installed them? I went to visions and the guy there couldn't fit them in. the magnets are over 3 inches deep. BTW i got mine at soundomain.com it was around $260US then add $35CDN for customs.
Old Jul 5, 2004
MrWong's Avatar
Bushido
The guy that did the install, worked at Futureshop, before that he was at Certified Radio, Auto Temp and Visions.
I know him personally he has been and installer for over 7 years. Unfortunately he is not doing installs anymore. Went on to something different.
You might need some custom work, such as custom spacers just enough so the window can still open and you can still fit the panel/grill.
The tweeter might be a bit harder, if you have a Si with factory tweets since the pod is so shallow. However if you look at the pod you will see a piece of plastic, you can cut that plastic off therefore making more room for your tweeters to fit in. The only problem is you tweeters will move around so you will have to epoxy the edges of the tweets to the inner edge of the pod.
As for the door speaker try shaving off some of the plastic on the grill.
Trust me man, these speakers can and will fit. You just have to do some minor custom work.
I would suggest that you do the install yourself, it will save you money and you will feel better about it.
If you know how to take the door panel off you are set, search the site. This site has a diy somewhere, it is very helpful.
Old Jul 5, 2004
kornsined's Avatar
oh i took it off already it's just that i don't have the material for making spacers or a jig saw to cut out a bigger hole. you know what's weird though the guy got the tweeter to fit fine. that's fuked up stoopid lazy ****. thanks for the help. i think i'm gonna try jb's. they're exspensive but i think they'll probably do it.
Old Jul 5, 2004
MrWong's Avatar
Bushido
You should try Decibels before JB's.
They are on the south side, they do really good work.
Prices are probally better then JB's.
I am not sure what the exact address is, the phone book is where I found when my friend needed some work done to his Integra.
Old Jul 7, 2004
kornsined's Avatar
Found out some good news. There's a sheath over the magnet that can be removed by breaking off the plastic label on the back of the mid driver. It'll give me an extra 1/4" so if i run into any problems that can be a possible solution.
Old Jul 11, 2004
kornsined's Avatar
Yes they're in. the *** at visions does not know what he's doing. do not go to the south side visions he also ran my rca's along my power wire which = engine noise. what a retard! JB's had no problems fitting them in.
Old Jul 11, 2004
Zerohour's Avatar
Zerohour is an unknown quantity at this point
Welli'm glad you got them in. I had the same problem with my REV speakers, but i had to put in a 1" spacer, curious what did they have to do?
Old Jul 11, 2004
kornsined's Avatar
same thing spacer but the first installer made one too big and didn't think to make it slightly smaller.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
doubledeuce2k2
Jan 17, 2004 02:27 PM
iLLuMiNaTi
Aug 16, 2003 12:21 PM
MangoEX
South Cali
Feb 2, 2003 10:59 PM
