8th Gen Si Tuning at Colletti Motor Sports. Moraine, Ohio
Driving up from Cincinnati to Colletti Motorsports near Dayton. Installing Vibrant Header and Flash Pro Manager to existing Mishimoto SRI and Vibrant StreetPower exhaust. 1 Hour on the dyno for tuning with Rick Williams. I'll post results when I get back.
Re: 8th Gen Si Tuning at Colletti Motor Sports. Moraine, Ohio
7 runs, 198-205hp, 149-154ft/lbs torque before Hondata FlashPro tune on the dyno today. Steve Colletti (owner) , Bill (tech), and Keith were about as good as you can get. They get the job done right. I highly recommend for anyone anywhere near or around Dayton, Ohio. Can't wait to go back for the custom tune with Rick Williams (freelance Honda/Acura Tuner).
Good numbers.132 ft/lb of torque with those mods seems sorta low for the K20AZ3.HP is dead on though at 200.
I though it was low this time. I was on the Dyno 2 weeks prior, after the mods installed and I remember gaining more torque, somewhere around 150. I'm not sure but I think I lost high end torque to correct a/f ratios...but notice this tune starts at 4500, If I remember correctly I gained more torque at a lower RPM. It's def. smoother then the base map, and considering it's my daily driver, I'll take it. < Correction...it's 132. at 78OO rpms where the cursor is set. Looks about 147ft/lb around 5800rpms... check the bottom right.
cizsak
Jul 21, 2015 03:39 PM
