Projects list...ohio tech talk.
Old Aug 9, 2004
reytito's Avatar
so whats everyone working on. oh come on now, lets not play the "i'm too cool to tell everyone" games. plus we can help each other out as we go if at all possible.
so me:
- auto to tranny conversion. bought complete tranny with ALL parts needed for $850 shipped. now the man hours to put it in.
- custom t3/t4 intercoolered turbo-ing process w/ custom manifold.
hows about you guys?
Old Aug 9, 2004
doubledeuce2k2's Avatar
1. springs with matt. going from neuspeed sport to eibach pro kit. my exhaust scrapes everywhere when i have 1 other person in the car.
1.5. raise shock plate in the back so the rear doesn't sag
2. upgrade busted endlinks when i do #1
3. install new subs (adire audio shivas), and build box.
4. install components (CDT HD-62's)
5. amp it all up
6. put in power steering as soon as i get a pressure hose for under the $190 majestic wants for it
thats the large of it
Old Aug 9, 2004
reytito's Avatar
how is driving w/o PS?
Old Aug 9, 2004
abmerop18's Avatar
Jam out with your clam out.
ill be boosting over winter also. custom turbo kit
Old Aug 9, 2004
it sucks. parking can be a bear, let alone parallel parking. but street driving i get used to it for the most part.
when you corner fast, it's up to you to keep the wheel from going some other direction though. makes me drive slower.
Old Aug 9, 2004
reytito's Avatar
what kind of kit are you throwing together?
Old Aug 9, 2004
abmerop18's Avatar
t3 super 60 turbo
tial 35 mm external wastegate
custom manifold
SLP return fuel conversion
HKS SSQV BOV
www.johnnyracecar.com intercooler (outlets on each side)
RSX injectors
ACT Clutch (already purchased and installed)
greddy profec-b spec II EBC
greddy e-manage
greddy turbo timer
custom 2.5" exhaust with turbo muffler
alcohol injection
thats about it. might have forgot a couple things, but thats the basics of it
im hopin to put out 200-210 whp and around 7 psi daily driven and 9-10 psi for the track with the alcohol injection
Old Aug 9, 2004
reytito's Avatar
t3/t4 turbo
custom manifold
dsm bov
RSX injectors
manual boost controller
safcII
greddy turbo timer
hayame 2.5 turbo cat-back
i'm hoping to put out 180hp around 7psi.
matt, can you explain alchy injection for me? thanks.
Old Aug 9, 2004
abmerop18's Avatar
sounds like we got pretty similar setups with the exception of fuel systems and bov's. one thing, if you get a MBC, make sure it is a good one cause if you gtet a cheap one you risk the chance of boost spikes and end up blowing your engine like that guy in the FI section.
as for alcohol injection, i dont know much about it besides that it add the extra fuel needed at higher boost to help the engine run better. most people setup alcohol injection to start around 9 psi.
Old Aug 9, 2004
abmerop18's Avatar
only thing i would change with your setup is the turbo. your gonna be spoolin around 4k RPM and that doesnt leave much time for boost between that and the redline. i have talked ot kevin and he says he regrets that his turbo spools so late. im opin mine to spool around 3300 rpm or so
Old Aug 9, 2004
C2i0v0i1C's Avatar
SuperMODrizd
getting the ***** ****a fixed
Old Aug 10, 2004
Jodster's Avatar
Post Whore General
Just little stuff to the Type S for now.
Revo SS
DCRH
Exhaust(Not sure what I'm going with yet)
Drop(not sure what I'm going with yet)
And I'm waiting it out to see what I'm going to do major wise. I still have not decided if I'm going to stay N/A or go F/I.
So either, Crower cams, Skunk2 springs and valves, K-pro, and 9K redline
Vs
JRSC or Comptech SC(When its released. Its in the works now) or Greddy Turbo kit or Cybernations Turbo Kit.
Regardless, I'll be getting LSD a new clutch and flywheel. I just can't decide if I want to ton of power. Its kind of pointless on a FWD car. Just going back and forth. But it will be a good year before I'm boosted if that happens.
Old Aug 10, 2004
abmerop18's Avatar
whats a DCRH?
Old Aug 10, 2004
reytito's Avatar
matt, i'm running a T3 instead of t3/t4 now...but yeah spooling at 4k won't be fun at all...but i'll see what i can do. maybe a t28 later sometime. what do i need to run some alcohol...cuz i'm afraid at 7psi, i may be running lean even with safcII tuned...dumbass stock FPR...what do you think?
Old Aug 10, 2004
abmerop18's Avatar
all you nned is to put the alcohol in your windshield washer reservoir and use the stock pump from that and add a relay to turn it on at 7 psi and route the tubing to a sprayer that injects in your charge pipe
Old Aug 10, 2004
whats a DCRH?
guessing its a race header produced by dc
all this turbo talk makes me want to...
Old Aug 10, 2004
reytito's Avatar
jody do yo know when cybernations guardian fuel system will be available?
Old Aug 10, 2004
Jodster's Avatar
Post Whore General
whats a DCRH?
DC Sports Race Header
Old Aug 10, 2004
Jodster's Avatar
Post Whore General
Its out for the RSX and new SI with their Stage one kit only. They are working on it with the Stage 2 and 3 kit right now.
It will be out with the kit they are getting ready to work on for the D17.
Also they are goingto be making it to work with other turbo kits. Isn't that nice. hahahaa
All I know is that I have read so much about the gaurdian that it is too goo to be true. But its all real.
I'll post some threads about it from Clubrsx.com so you can find out alittle more about it.
Old Aug 10, 2004
Jodster's Avatar
Post Whore General
Info on the guardian
http://forums.clubrsx.com/showthread.php?t=176874
A guy with the guardian.
http://forums.clubrsx.com/showthread.php?t=183897
Old Aug 10, 2004
reytito's Avatar
matt where can i get more info on the slp conversion kit?
Old Aug 10, 2004
abmerop18's Avatar
the FI forum
Old Aug 11, 2004
sorry to do this but
i can't seem to pm these shifter pics to jodster so i load them here
help me figure out what shifter this is! i got it free with the car
ID:	35706   Click image for larger version
Old Aug 11, 2004
abmerop18's Avatar
revo short shifter? i dont know. unless that is your stock one he replaced with an aftermarket one that is already in your car? it looks used, so im gonna guess it is the stock one.
look for an acura name or something on it
Old Aug 12, 2004
Jodster's Avatar
Post Whore General
Thats the factory shifter for the 7thgencivic. Its not a Revo SS.
Old Aug 12, 2004
doh!
like i told jodie, the only identifier on it is this japanese price tag looking thing. thats it
he told me he had the short shifter but he went back to stock because they were fairly short throws anyways. doesn't revo make a non adjustable one?
EDIT: now i see where the adjustment can be made. i bet this is the non adjustable shifter that preceded the current one. it looks JUST like the revo except for that adjustment.
Old Aug 12, 2004
abmerop18's Avatar
i just purchased some RSX-S injectors
Old Aug 12, 2004
mikalem's Avatar
mikalem is on a distinguished road
I'm so poor... the rest of my money went to the motorcycle The Civic is going to be unloved for a while as it needs to be paid off, and have some door dings fixed (I HATE parking in this god damn city, no one can watch their doors, or their shopping carts... it's rediculous) I'm just finishing up the motorcycle tweaks - new exhaust and intake, rejeted the carb and got a new rear tire as well. Next up, clip ons for the handlebars and a new wind screen. Then paint. Yay!
/watches money go down the drain!
Old Aug 12, 2004
^^^ but see your wasted money actually gets you some speed on the bike enjoy it!
Old Aug 12, 2004
reytito's Avatar
i just got some last week.
$60 shipped...not a great deal at all...but w/e.
