anyone want a bike?
Old Jul 28, 2004
reytito's Avatar
anyone want a bike?
I've decided i want a road bike now. no more trying to find trails in OHIO to MTB. i got this bike 3 months ago for $525. Ive ridden this off road ONCE, and a daily 5 minute commute to work. NEver crashed, never wiped out, cuz i'm such a good rider . some chain slap, but other wise like new. disc brakes work sweet, front fork is very plush but can be stiffened by twisting. id rather not part, but i really want a road bike.
WANTING $400 pickup or delivery. i will have pics of the actual bike tonite. actual bike is beige color.
SPECS:
FRAME - A1 Premium Aluminum, DT/HT 3D box gusset, forged dropouts w/ reinforced disc mount and eyelets, replaceable forged alloy derailleur hanger, disc only, designed for 100mm travel fork
FORK- Marzocchi MZ Comp, 100mm travel, preload adjust, steel steerer, elastomer/coil spring
HEADSET- 1 1/8" threadless, sealed loose ball, alloy cap
STEM- Specialized "Mobius", alloy, 10 degree rise
HANDLEBARS- Alloy, 38mm rise, 9 degree sweep
TAPE / GRIPS- Specialized Durango double density Kraton
FRONT BRAKE- Shimano 475 mechanical disc, 6" rotor
REAR BRAKE- Shimano 475 mechanical disc, 6" rotor
BRAKE LEVERS- Shimano Alivio
FRONT DERAILLEUR- Shimano Acera, 31.8mm clamp, bottom pull
REAR DERAILLEUR- Shimano Deore
SHIFT LEVERS- Shimano Alivio
CASSETTE- Shimano HG-50, 8-speed, 11x32t
CHAIN -Shimano IG-31
CRANKSET- Truvativ 5-D, alloy, capless bolts
CHAINRINGS- 42t AL-7075 x 32t heat-treated Cr-Mo x 22t heat-treated Cr-Mo, replaceable
BOTTOM BRACKET- Truvativ, 68x113mm, square taper, sealed cartridge bearing with double crank stops
PEDALS- 9/16" alloy platform w/ Cr-Mo spindle
RIMS SUN- "DitchWitch" 26"x1.75", double wall, eyeleted
FRONT HUB- Joy-Tech, disc, 32 hole, ground race double sealed loose ball w/ alloy QR
REAR HUB- Joy-Tech, disc, freehub, 32 hole, ground race double sealed loose ball w/ alloy QR
SPOKES- 2.0mm (14g) stainless steel, brass nipples, L262/R264mm front, L264/R262mm rear
FRONT TIRE- Specialized Enduro Sport, 26"x2.2", wire bead
REAR TIRE- Specialized Enduro Sport, 26"x2.2", wire bead
TUBES- Specialized schraeder valve
SADDLE- Specialized Body Geometry Sport ATB
SEAT POST- Alloy 30.9mmx300/350mm, micro adjust
SEAT BINDER- Alloy QR, 36mm I.D.
NOTES- Chain stay protector, reflectors, clear coat, owners manual
Old Jul 28, 2004
Jodster's Avatar
Post Whore General
Big Pimping. Hahaha
If I was motovated to pedal a bike I would buy it from you. I'm just lazy.
Old Jul 28, 2004
reytito's Avatar
get off your lazy *** and pedal. with my help and $400.
Old Jul 28, 2004
Jodster's Avatar
Post Whore General
Why should I pedal when I can drive?
Can you see me pedaling fown I-71 to get to work every morning?
Old Jul 28, 2004
mikalem's Avatar
mikalem is on a distinguished road
Exactly.... I'll stick with my motorized version
Old Jul 28, 2004
bluericeburna2k2's Avatar
bluericeburna2k2 will become famous soon enoughbluericeburna2k2 will become famous soon enough
damn i love thoes bikes with the disc brakes! if i lived closer to campus id buy it.
Old Jul 28, 2004
reytito's Avatar
PMd you
ce01cvcex
Nov 6, 2023 02:35 PM
jordan1794
Jun 8, 2015 04:03 AM
BrotherSound
Nov 8, 2002 11:10 AM
