RSX Injector Fitment Question
Old Nov 22, 2006
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
I have a set of RSX Type S injectors for my D17. I only have the injectors with o-rings. Do I need the RSX connecter/harness or will my D17 connectors clip onto the RSX injectors no problem?
Old Nov 22, 2006
boostedEL's Avatar
boostedEL is an unknown quantity at this point
If im not mistaking, rsx type-s injectors are a plug and play deal. the only thing is that they are taller so you have to make spacer for them.
Old Nov 22, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
yes out clips plug directly into them. by spacer, he meens that the rsx injectors are longer so your orignal fuel rail mounting bolts will no longer be usable.
What I did was get 2 nuts the same thread as the mounting bolts and tighten them against each other so you can back the stud out. Bring that stud to a hardware store and tell them you want longer bolts, the same size. Becareful when tightening down so you don't crack the injectors. Use the stock plastic spaces if you cant. I didn't. Good luck.
SimpleUser
Apr 24, 2021 02:54 AM
SuperNova18
24
Sep 2, 2019 10:46 PM
fred57
Aug 1, 2015 08:45 AM
Green02civic
Jul 27, 2015 10:48 PM
jody501
Jul 10, 2015 11:01 AM
