where is the TPS wire on the 7thgen
Old Jun 8, 2003
Parisdreams's Avatar
Parisdreams is an unknown quantity at this point
I had the Zex wet system sice it was released. But didn't want to use it until the warranty was up. No 37,000 miles later I'm ready to hook up that last wire. (by the way although i have never feed N20 into the motor i feed the air about 2 tanks worth). Can anyone out there guid me to the TPS wire. You know when, and what color. A pic or Diagram would be awsome. I much rather have a startng point before i go stripping and testing wires.
Old Jun 8, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
In Connector A on the ECU, it's the one in the 15th terminal. (Left to right, top to bottom). It's a red/black wire. the ECU is oriented on it's side behind the glove box. The top connector is Connector A. If you need more help or a better description, let me know.
Old Jun 8, 2003
thanks alot. now i must go Ha, Ha, Ha, Ha; sorry i left thebottle open.
Old Jul 3, 2003
NashVegasEX's Avatar
NashVegasEX is an unknown quantity at this point
so do the red (power) and white(TPS) wires both go through the firewall?
amrhamed
Aug 7, 2015 11:39 AM
Martinez8o5
Jul 31, 2015 10:58 PM
sch2cm
Jul 21, 2015 09:58 PM
Jul 12, 2015 11:54 AM
