K24a4 Em2 swap
Old May 5, 2022
GabeV's Avatar
GabeV is an unknown quantity at this point
K24a4 Em2 swap
Hello all! Im here wondering about which ECU I need to put the Accord engine into my 2005 em2 I have the original engine harness and raa-a06 ECU both from the same car am I able to use that Computer and harness and simply wire it to my dash or use a conversion or how does that all work?
Also wondering I have the RSX Base subframe on order what control arms do I use Acura ones or can I reuse the civics lower control arms.
Learning how to do all this so if there is a thread i missed that has this information a link would be awesome. Thank you all!
Update: I have the k24a3 out of an 04 accord not the a4
Old May 6, 2022
BrotatoChip's Avatar
Super Moderator
Re: K24a4 Em2 swap
Most people get Kpro when they swap. I'm not sure if you can buy a conversion harness (or modify the one you have) to make the Accord ECU work in the Civic. I suspect you could make it work but you'd need to study schematic for both or do some more Google searching.
Civic's control arms will work if you're staying 4-lug.
FRSam
Engine Swaps
59
Jun 26, 2021 11:08 PM
AddictionJDM
Engine Swaps
Apr 2, 2016 09:36 PM
NastyNunez
Oct 27, 2007 06:32 PM
DAQIUN
May 30, 2006 10:48 PM
Dark2k1
Engine Swaps
Apr 11, 2005 06:55 AM
