Just to Verify
Old Jan 16, 2020
4xdon's Avatar
4xdon is an unknown quantity at this point
Just to Verify
Is an RSX (DC5) subframe a direct bolt on to an EM2 chassis? And if it is, would I still need custom engine mounts to do a k20a swap?
Old Jan 16, 2020
BrotatoChip's Avatar
Super Moderator
Re: Just to Verify
Subframe is a bolt on to the EM2 chassis, this means you can use OEM RSX or EP3 front and rear mounts. The side engine mounts bolt directly to the chassis though. You will either have to buy K swap mounts or drill out the welded mounts on an RSX/EP3 and weld them onto your car.
Em2dreamer
Engine Swaps
15
Feb 19, 2009 12:13 AM
zcomsto
Engine Swaps
Jan 5, 2009 02:56 AM
streetthrowback
Engine Swaps
Oct 20, 2007 07:30 AM
boostaddict
Engine Swaps
Aug 27, 2005 10:06 PM
